Hello community
first of all, VDJ 8 is great ! but i believe i found a bug:
in version 7 I always used the filter folder "compatible songs" to see the song witch fit in key.... but in version 8 this doesn't work :/
in the screenshoot you can see my problem:
the keys doesn't fit
the Compatible songs folder is like this "Bpm Difference <= 7 and Key Difference <= 1"
in version 7 the keys were like this:
http://es.virtualdj.com/image/70814/82983/C__Dokumente%20und%20Einstellungen_chackl_Eigene%20Dateien_kamelot%20key%20A4%20(1.png
i hope you can help me with this problem
Posted Tue 13 May 14 @ 11:26 am
me the same problem
new install v8
all mp3 new scanning and analysing
make a filterfolder "compatible songs" with "Key Difference <= 1"
load a track with "D / 10B" in Deck 1 an click on the filter Folder compatible songs
and the Answer from vdj8 see in the picture ;-)
new install v8
Posted Fri 23 May 14 @ 11:07 am
