Forum: German Forum
Topic: Übersicht der aktuellen bzw. laufenden Builds und Fixes der Version 8 - Page: 5
22.03.2015
Build 2185
-Improved video engine
-Stutter hot_cue mode now uses last pressed hot_cue
-Improvements to repeat_stop
-repeat_start commands with same identifier now reset
-No mouse-over graphics and tooltips when using touch screen
-Fix hotcuemode play
Posted Mon 23 Mar 15 @ 12:58 am
30.03.2015
Build 2191
-Backspin/forwardspin detection speed increased to +-50%
-crossfader_disable action takes effect instantly
-custom sort fields working in filter folders using group by
-Fix 'error' displayed on deck on fresh install if samplerate is not 44100
-browsed_file_color "reset" to clear the set color
-get_rotation_cue added
-mute also mutes sampler if routed through deck effects
-fix problem with slicer buttons sometimes lighting up randomly
-if crossfader is disabled, it doesn't affect video crossfader in auto mode anymore
-fix midi clock output setting not saved when no custom mapping was created in some cases
-karaoke files are never zoomed or stretched to ensure lyrics are properly readable
Posted Mon 30 Mar 15 @ 1:03 am
30.03.2015
Build 2195
-Mono mic works with WASAPI when automatically selected as channels 1/2
-get_level 'mic' working
-karaoke videos not zoomed/stretched anymore
-repeat_start executes NOREPEAT actions once
-Fix case sensitivity issue with group by in filter folders
-Fix midi color table
-Fix browser_scroll 'bottom' when used on folder list
-Analyze 'Desktop' limited to actual files/folders on desktop, not including 'This PC' and 'Network'
-mapped network drives can have their own database
-Fix repeat_start not usable for certain actions (such as stop, play, pause)
Posted Sun 05 Apr 15 @ 10:53 am
12.04.2015
Build 2202
-Fix repeat action regression
-zeroDb has drop-down with db values for easier access
-VU meter performance improvement
-faderStartStop option doesn't switch to different cue if deck already stopped
-Config Window stays on top on OSX
-Reset Sort Order right-click option added for folders when a order file is present
Neues Deutsches Sprachpaket: http://www.virtualdj.com/addons/16766/German_8_x.html
Posted Sun 12 Apr 15 @ 1:02 pm
15.04.2015
Build 2204
- Swap Ctrl+Drag and Shift+Drag to match Explorer (Copy, Move)
- Fix storing saved loops defined in seconds instead of beats
- 'Stop on end' option added to backspin effect
- Fix parsing iTunes database with network paths
- Move/Delete file doesn't fail when file was still selected in prelisten
Note: Copy Move actually show wrong Tooltip. Will be fixed in next update.
Posted Thu 16 Apr 15 @ 5:15 pm
BraenzuPRO InfinityModeratorMember since 2007
17.04.2015
Build 2206
-Fix regression copy/move tooltips from b2204
-Fix word wrap on action description on mac
-Fix VDJScript documentation url on mac
-Fix change log not appearing on mac
-Improved checking of moved files for Virtual Folders
Posted Fri 17 Apr 15 @ 11:05 am
22.04.2015
Build 2212
-fix some broken netSearch results
-Allow scrolling in effect list drop-down with browser_scroll action
-SamplerOutputTriggerDeck option available with master/headphones audio config as well
Posted Wed 22 Apr 15 @ 1:56 pm
26.04.2015
Build 2218
-effect_select can scroll through effect popup if opened
-sample_color working for remix mode
-internal effects can now also be ordered in sub-folders
-Plugin subfolder with name 'ignore' will be ignored while scrolling with effect_select, or random video transition selection
Posted Wed 29 Apr 15 @ 1:30 am
RobRoyPRO InfinitySenior staffMember since 2012
30.04.2014
BUILD 2229
-Fix effect_select regression causing effect filters not to work properly
-Fix automatic re-analyze overwriting custom bpm/phase when scan version is updated
-Fix reading certain playlists on mac
-Sort playlists listed in folders alphabetically
-Ensure zeroDb config value does not get invalid
-Improve automatic deck assignment for controllers when some controllers have been assigned manually
-Custom remix points don't get overwritten when re-analyzing
-get_slip_active action added
-Fix login using Google ID broken
Posted Thu 30 Apr 15 @ 9:49 am
01.05.2015
BUILD 2231
- CUAudio catalog fallback to NetSearchAudio automatically
Posted Fri 01 May 15 @ 10:17 am
07.05.2015
Build 2245
-Fix problem writing certain mp3 tags
-cdg karaoke tracks can be rendered in 16:9 aspect ratio
-zoom letterboxing option allowed for karaoke tracks again
-Fix multi-window skin problem with windows that are initially hidden
-get_time_sec 'absolute' fixed
-deck x linein initializes that deck if it wasn't available yet
-get_rotation_slip added
-slip position added to gemini waveform
-no slip interference when scratching while pausing
-shift+drag can be used to move folders
-fix skinRhythm couldn't be on a panel that moved
-fix netSearch
Posted Wed 06 May 15 @ 11:18 pm
14.05.2015
Build 2265
-fix get_beatgrid action to match description
-fix decoding wma files when output samplerate is 192kHz
-fix for numark nv automatic deck selection of displays being wrong
-support for custom mixer order for 4 deck controllers
-new action effect_slider_active
-Fix video drawn not pixel-perfect in some cases with DirectX
-effects_used 'deck' and effects_used 'master' actions
-Fix prelisten crash when using prelisten after deleting or moving a file previously prelistened
-Fix browser_scroll not scrolling from correct location after dragging a song to a different location
-new action get_playlist_time
-Escape key works to cancel security load window
-Fix possible issue reading remix and remixer field from Ogg and Flac tags
-Fix check to ensure VirtualDJ is visible on screen
-Fix performance problem with Reverb and Phaser when track paused
-Fix popup alerts from config window hidden on Mac
-Fix config record file selector hidden on Mac
Posted Fri 15 May 15 @ 6:09 am
22.05.2015
Build 2282
-Fix 'effects_used "deck"' action
-Fix for relativetouchslider option on HID sliders
-Fix for rhythm wave sometimes not fully drawn
-Better results for netSearchAudio
Posted Fri 22 May 15 @ 5:45 am
05.06.2015
Build 2305
-new ContentUnlimited Audio core catalog
-new VDJRemote v8 on iOS and Android
-Fix for wide-screen karaoke file rendering cutting off part of the side
-Mixer order used for audio channel routing
-playlist_load_and_remove and playlist_load_and_keep actions use the first item from the list instead of the selected to match their description
-splitHeadphones master volume at 100% by default
-fix for hercules dj controller custom buttons not showing effects anymore
Posted Sat 06 Jun 15 @ 1:00 pm
12.06.2015
Build 2325
-New core catalog for ContentUnlimited Audio
-param_1_x action added
-browser_remove action added
-Fix for cdg widescreen playback
-improved using 2 timecodes with 4 decks
-automix skip/mix_now length can be customized (automixSkipLength option)
-BPM editor can be closed using escape key
-exclude playlists from recursion in system folders
-some fixes to automatic deck assignment for controllers
-Fix reset sort order also hiding virtual folders
-Effect ini file is stored for plugin instance that was last modified
-Fix options window at 250% dpi
-Slideshow sorted by filename
-Cover engine speed-up when loading from cache
-Fix possible plugin engine crash on close
-Rewire not re-initialized on each scan to prevent audio dropouts
Posted Sun 14 Jun 15 @ 6:26 am
18.06.2015
Build 2334
-Fix bpm editor unable to type bpm manually
-Fix select logo from options on mac causing selection dialog to appear behind options window
-Fix logging of found sysex id
-Fix 'ignore' folder not ignored by effect_select +1/-1 correctly
-POI editor can be closed using Escape key
-Fix camelot key search
-Fix being able to move internal video transitions into a subfolder
-Add string parameter "random" to video_transition_select to allow for a manual random transition selection
-selectPlugin with float index uses entire plugin list
-Fix mapper KEY disapearing on selection for some controller mappings
-MIDI definitions without output channel defined can send on the same channel as incoming messages instead of fixed to channel 0
-vdjRemote browser can browse and add to sidelist, karaoke or automix lists (needs vdjRemote 8.0.2334 or higher for full functionality)
Posted Fri 19 Jun 15 @ 3:06 am
21.06.2015
Build 2338
- final ContentUnlimited Audio catalog
- new action browsed_file_reveal to open OS file manager to file selected in browser
- new action set_browsed_file_bpm to set or adjust the BPM of the file(s) selected in browser
- fix dialog hidden for manually adding remote IP on Mac
Posted Sun 21 Jun 15 @ 11:30 pm
28.06.2015
Build 2345
-Fix sorting by last modified date
-Fix problem writing mp3 id3v2.2 tags
-Fix problem writing mp3 id3 tags when tag size needs to be increased
-CDJ nexus colored waveform
-revert default channel for midi out
-add remix to file names when caching cu files
-improve tag reading for cached cu files
-get_deck_color "absolute" action added
-fix possible click sound at end of automix
-Fix problem writing id3 cover when tag needs to be increased in size
-Track cleaner closes prelisten player on close so that song can be reloaded properly
-fixed update popup appears behind config window (if open) on Mac
-new video transition 'additive' which is useful for video fading with the volume faders
-Fix possible deadlock while downloading
-Save root in playlists to be more compatible with other programs
-Fix netsearch audio files getting video icon sometimes when saving to cache
-Global sampler focus for controllers with 2 sides but single sample controls (use "deck master sampler_loop +1" for example to use)
-samplerVideoVolumeLink option added
Posted Sun 28 Jun 15 @ 10:03 am
05.07.2015
Build 2348
-Fix POI editor prelistening producing buzzing sound with loop set in seconds
-Fix crash when adding file to automix twice from remote
-Fix mic not included in headphones output when headphones mix is on
-Touch wheel backward/forward spin threshold configurable
-seek action stops before beginning and after end of track
-Content Unlimited search folders always show results regardless of filters
-Scrolling using jog wheel works similar to scrolling using browser_scroll
Posted Mon 06 Jul 15 @ 1:58 am
12.07.2015
Build 2352 (Public)
-Jog returns to wheel mode when loop disabled and it was in loop move mode
-zero parameter for midi pitch slider definition
-Escape binary characters in database xml to be compatible with external xml tools
-Auto-generate video edit by dropping video file on video preview of audio file
-Fix some old xvid video's not playing back correctly
-browser_sort action accepts + in front of column name to force ascending sort
-scratching on the skin allows backspins
-New script command playlist_randomize_once that performs a 'Shuffle Once' on the playlist
-Add file selector to iTunes database file setting
-Fix Additive transition on Mac
Posted Sun 12 Jul 15 @ 2:37 pm
78%
