Forum: German Forum
Topic: Übersicht der aktuellen bzw. laufenden Builds und Fixes der Version 8 - Page: 2
BraenzuPRO InfinityModeratorMember since 2007
Build 1806: VIP_BUILD & PUBLIC_BUILD
-Fix no sound when scratching while paused (from build 1802)
-Fix placement of Recorded file button on record page after recording
-Fix crash when trying to write database on a read-only drive
-Fix incorrect ".vdjfo.subfolders" being created when moving a virtual folder
Posted Sun 25 May 14 @ 2:03 pm
RobRoyPRO InfinitySenior staffMember since 2012
27/05/2014
Build 1814: ( nur mit aktiver get-beta-builds Option )
-Fix batch-analyze sometimes giving wrong bpm results
-logUnsuccessful searches works with CU disabled
-Fix renaming of virtual folders
-Files scanned in order when added to automix
Posted Tue 27 May 14 @ 9:18 am
RobRoy wrote :
27/05/2014
wo finde ich die einstellung denn genau?
Posted Tue 27 May 14 @ 10:16 am
Geh auf "My Account". Dann ganz unten bei Get Beta Builds" einen Haken setzten....
Posted Tue 27 May 14 @ 10:17 am
29/05/2014
Build 1819:
-Fixes some videotransition plugins (mac)
-YUY2 support for Camera plugin (windows)
-Fixes Virtual Folders not stored some times
-Fix line endings on search log (windows)
-Fix renaming mp3+cdg files
-Fix SongPos shadow on high-dpi screens
-Fix possible skin panel crash
-Read track number from certain m4a files
-Fixes text display on Denon controllers (mac)
Posted Thu 29 May 14 @ 3:06 am
30/5/2014
Build 1820:
- fix regression bug on camera plugin (windows)
Posted Thu 29 May 14 @ 11:45 pm
04.06.2014
Build 1828:
-Video fps shown in cpu usage tooltip
-Deck video previews show visualisations too
-Default Pitch bend sensitivity lowered
-Remix field searchable
-Improve midi detection (mac)
-Camera plugin improvements (pc)
-Sample volume and singer column selectable with touch screen
-Fix delete confirmation on Virtual Folders
-Fix colorize video effect
-Fix bug reading Traktor cue points from tag
-Fix lock-up when resizing skin with sampler opened
-Fix crash resizing sample editor with video
-Fix crash loading certain custom skins
-Fix some bugs on the tablet skin
-Fix issue with multi-screen (mac)
-Fix crash when modifying controller mapping
-Fix images for custom definitions not working
-Controller images shown in correct size on high-dpi displays
-Chinese translation updated
Posted Wed 04 Jun 14 @ 7:59 am
08.06.2014
Build 1834
Fixed saving samples that are encoded in an uncompressed format
-Fix translation for root elements not working correctly
-Auto-gain still applied when fake_gain is used
-Missing folders in VirtualDJ documents folder recreated on startup
-User fields in filter folder can work both numeric and string
-resetKeyOnLoad option added
-New v8 'Text' video effect
-Sample editor mouse cursor getting stuck on mac fix
-videoFPS config option used (should reduce cpu/gpu usage)
-Improved visibility when moving position of items in list
-Fix 'deck master fx_slider' type of actions not working correctly on controllers
-Some missing translations added
-Fixed storing of order when playlist opened in sideview
-Fixed negative time display
-Fixed crash when doing fast scratch on loop boundaries
-Selecting the same effect in 2 slots will always load the same instance now
-Some small scratch wave optimizations
-Fix analyzer marking karaoke songs as regular music files
-Small rhythm wave performance improvement
-Fix possible crash reading corrupt mp4 tag
-Don't enumerate ._ mac metadata files
-Fix possible automix glitches with pitchQuality 2
Posted Sun 08 Jun 14 @ 5:52 am
17.06.2014
Build 1845
-Fix relative playlist paths not working on mac
-Some improvement for SCS.1d pitch stability
-Improve loading plugin ini file performance
-Fix VST plugin GUI broken after closing with windows X button
-Fix video window not responding when video initialized from controller
-Improve reading character encoding from text files
-Copy and move folders fixed
-Some skin fixes
-automixAutoRemovePlayed option also removes from automix when played manually
-Fix HomeFolder when it could have a back-slash at the end
-Fix memory leak in sample editor
-Filter effect added (for use on controllers with effect selection/knobs but no dedicated filter knob)
-Database cleanup removes missing file flag for files that exist
-Brightness parameter added to colorize effect
-Fixed sinc filter bug causing scratch with pitchQuality 2 being too loud
-Improve vid/pid detection for audio on mac
-Fixed selecting plugins using sliders
-Fixed video samples not properly released when video engine restarts
-Optimized framerate on mac (using DisplayLink to exactly match monitor refresh rate or half of monitor refresh rate)
-By default, skin is now synced at half the display refresh rate
-Improved text drawing performance on mac
-<bar> midi output can accept ccmsb
-Secondary sort order
-Fix pitch problem with timecode during lead-in
-Added skin fps to cpu meter tooltip
-Skin fps now more close to configured skinFps option (decreases cpu usage)
-Fixed "Full Kill" equalizer
-Fixed ordering and renaming of virtual folders
-Text drawing performance improvement (mac)
-Fix sampler_loop +1/-1 without slot number
Posted Tue 17 Jun 14 @ 6:31 am
23.06.2014
b1855
-Fix config window constantly refreshing when some ASIO soundcards disconnected
-Ignored controllers no longer make license window pop up
-Fix auto-gain off with unanalysed songs causing gain to change
-Karaoke background music works with only 1 song in automix list
-Sample mute also hides video
-Double-click song while in automix only mixes to next song when done from within automix list
-Some pitch improvements for denon motorized platters
-Fix pitch "all" and pitch "dual" actions not working
-Fix metronome on mac
-Fix favorite folder being created when mouse moved only one pixel while clicking folder
-Fix timecode not stopping playback when moving needle past end of song
-Fixed controller's recommended skin dialog wasn't showed
-Fix v7 tracklistings not correctly copied on mac
-Fix creating new playlist not working on mac
-Fix some sort bugs causing play time to be ordered wrong, and playlists not showing in their original order
-Pitch slider allows min parameter (for fixing reloop rmp3 pitch slider)
-pitch "touchrelative' for touch sensitive pitch sliders
-Fix bug reading iTunes playlist names
-Fix some Promo Only video crashing on load
Posted Mon 23 Jun 14 @ 11:41 am
01.07.2014
Build 1870
-Fix writing flac cover
-Fix prelisten getting broken playing songs with samplerate smaller than output samplerate
-Logout disabled in tradeshow mode
-Device definitions can have platform definition to limit to pc or mac
-Improve default resolution selection of camera plugin
-Fix header not written for .cue file
-Fix unable to re-order automix list when loaded from virtual folder or history folder
-Fix blackouts on some systems when skin fps is 30
-sampler_volume_master added for a master volume for sampler
-Fix possible analyzer problem when analyzing files with different sample rates
-Fix direct pc-to-pc broadcasting on mac
-Fix keepSortOrder false not resetting sort orders
-Synchronized play/cue now snaps to nearest beat instead of always going before the requested position
-fill="no" parameter for note bar midi definition added
-Fixed duplicate in list of controllers when buying PLUS license
-Full Kill eq improvement
-New "device detected" popup window
-UTF8 BOM marker written for playlists (fixes playlists becoming unreadable in vdj 7)
-sampler_bank doesn't block midi thread anymore
-Fix pitch-lock when pitch range is 100%
-Fix plugins unable to send "effect_activate" in some cases
-Fix audio automix removing video output of other deck during transition
-When a soundcard is not present on launch, use the internal soundcard until the one from the config is reconnected
-Fix HID controllers hot-plug on mac
-Fix soundcard hot-plug on mac
-Improve HID scan time on mac
Posted Tue 01 Jul 14 @ 12:14 am
01.07.2014
Build 1872
-Fix audio fallback regression bug from b1870 on mac
-Fix browser_sort action query in non-english
-Fix finding missing/moved files in virtual folders
-Fix possible lock up when pitch gets too large due to activating pitch_lock at -100%
Posted Tue 01 Jul 14 @ 1:58 pm
Posted Thu 03 Jul 14 @ 1:32 am
06.07.2014
Build 1878
-Fix problem with microFrames on mac that can cause image of previous video being shown when newly loaded video is of lower resolution
-"set_firstbeat" action added
-Fixed motorized platters behaving strange when platter was held still
-Fix distortion effect possible glitch when turning on
-Fix possible audio glitch when restarting reverb
-Fix phaser effect possible glitch when turning on, and high cpu usage when no music playing
-Fixed "file already exist" warnings when trying to reimport history after settings.xml was deleted
-Improve performance of browsing folders with zipped karaoke files
Posted Sun 06 Jul 14 @ 12:52 pm
14.07.2014
Build 1890
-fix crash when closing vdj with new device window still open
-Read audio cd's
-Fix set_firstbeat
-Improved midi device detection on mac
-Fix lockup when adding lots of files to automix
-Fix audio drop-out when moving files around in a big automix list while automix enabled
-Fix play_sync choosing closest beat
-German language update
-Greek language updated
-get_beat fixed when samplerate was different from 44100Hz
-Loadsecurity 'silent' added
-Ignore dash in search when copy/pasted
-Fix some keys not showing when key detection is set to electronic instead of broad range
-Option to stop showing the login window on launch if you don't want to log in
-Can record wav files
-Fix problem with non-normalized utf characters in path names on mac that prevented cdg files from being read for these files
-Fix bug where .cdg file could be erased when non-normalized utf character were in the path name on mac
-Fix flashes on secondary screen when using videoForceFullscreen and focus to vdj is lost
Posted Mon 14 Jul 14 @ 1:40 am
20.07.2014
Build 1897
-Fix crash on reading audio cd
-Fix sort on file path
-Fix wav recording
-Fix pickup controller mode not working anymore for sliders on mac
-Fix param_mod
-Fix Cmd-Q on mac not triggering close protection
-Double-click close button no longer bypasses close protection
-Repeat="yes" option for midi input buttons in definitions
Posted Sun 20 Jul 14 @ 9:54 am
30.07.2014
Build 1900
-Fix 'Remove' option in right-click menu in playlist not always showing up
-Camera plugin remembers selected resolution
-Fix crash when sorting in some situations
-Fix midi detection for bcd-3000
-Right ctrl/alt/shift can be used independent from left in shortcuts
Posted Wed 30 Jul 14 @ 11:11 pm
31.07.2014
Build 1901
-Fix NetSearch broken for some files since Wednesday
-Fix possible block on exit when still opening CU files
-Hide files starting with ._ on windows
-Fix cover not always shown on cdj-2000
-Possible HS-5500 improvement
Build 1902 (MAC)
-Fix problem with autoupdate sometimes not updating correctly
Posted Thu 31 Jul 14 @ 6:24 am
06.08.2014
Build 1907
-Improvement for motorized jog wheels holding the platter
-Fix position jumping while scratching with serato vinyl
-Possible fix for crash on playing cdg files in some cases
-Drag&Drop from Finder working on mac
-Fix empty custom_button used from a controller
-virtualfolder_add fix
-prelisten off fix
-ONEXIT/ONINIT called when switching controller mapping
BUILD 1910
- fixed translations not showing accents correctly in uppercase
- fixed using sampleSet zip files with banks and/or folders
- default 4deck skin can show 3 fx slots per deck (need a full install, autoupdate will not update the skin)
Posted Thu 07 Aug 14 @ 4:13 am
14.08.2014
Build 1918
-Fix downloaded plugins name on mac
-Fix playlist filename with accents when saving from automix
-Fix click-through of custom skin menus
-ccback added for jog wheel for controllers with different cc value for forward and backward movement
-Prelisten no longer stops working when selecting a missing or broken file
-recordWaitForSound fixed
-Fix possible automix crash when playing video
-Fix playlist copy to/move to context menu options
-Fix v7 import of Virtual Folders with certain characters in the name (*,?,/,etc)
-Fix cdj900/2000 jog display glitch
-Improve use of some icons for cdj900/2000
-MP4 recording uses AAC for audio instead of mp3 (fixes playback on mac in iTunes/Quicktime)
-Don't automatically load songs on invisible decks
-Fixed artwork covers when using linein
Posted Wed 13 Aug 14 @ 11:12 pm
31%
