Topic: Sound Quality Issues
DjGazUKPRO InfinityMember since 2005
Hi.
I've just installed VDJ 8 on a fresh install of Windows XP.
Previous versions work fine, but now all the sound is distorted. Sounds like the gain is way too high. I've tried to alter the gain but it still sounds like it's playing underwater.
I can't find how to change the sample rate, but not sure I should as it works fine on my other laptops.
Any ideas?
Thanks
Posted Tue 13 May 14 @ 4:29 am
Check your wasapiSharedMode setting. Selecting "yes" seems to help with most issues.
Posted Tue 13 May 14 @ 4:31 am
Thanks, but didn't change anything. Still sounds distorted. Everything else installed on this PC plays fine.
Posted Tue 13 May 14 @ 4:36 am
With wasapi set to yes, please close your browsers and vdj and try again.
Posted Tue 13 May 14 @ 4:38 am
This guy had a similar issue and found a solution. Try this:
outofthisworld wrote :
it was the Overclock on the performance setting, had to show advanced options.
Posted Tue 13 May 14 @ 4:40 am
Thanks for your help guys.
I just turned off "UltraLatency" and all is working fine :)
I would guess it has something to do with DirectX as this is a brand new install and nothing like DirectX has been installed yet.
Cheers!
Posted Tue 13 May 14 @ 5:24 am
