Hi guys, finding myself unable to use my onboard laptop speakers with the new version.
Here's my output setup...
And here's the error I get....
I've enabled Wasapi shared in advanced settings, it had no effect.
Posted Mon 12 May 14 @ 9:59 am
Any ideas? Doing my head in trying to work it out
Posted Mon 12 May 14 @ 11:17 am
Try enabling wasapiShardedMode in config
Posted Mon 12 May 14 @ 11:20 am
I have (see bottom of my post) still no good
Posted Mon 12 May 14 @ 11:35 am
Virtual DJ is NOT RELEASING sound card drivers to other devices in windows 8. If I tab out of vdj i should have FULL control of my usb soundcard for youtube, etc
Posted Mon 12 May 14 @ 11:37 am
Do other programs output sound without any issue whilst VDJ is open?
Your post is not related to this issue!
But your answer here:
Posted Mon 12 May 14 @ 11:38 am
Cauthers, I think you need to reboot. I had that same error and a reboot sorted it.
Posted Mon 12 May 14 @ 11:49 am
Thanks groovindj I'll try that. No other audio (firefox/windows media player) works when vdj is open but resumes when i close vdj.
Posted Mon 12 May 14 @ 1:37 pm
Cauthers wrote :
No other audio works when vdj is open
That's the wasapisharedmode option as mentioned above. Exclusive mode (default) prevents other software accessing the soundcard.
Posted Mon 12 May 14 @ 1:46 pm
