zenarado wrote :
This is my stream: http://sc6.djstream.net:8664
This one works.
Posted Mon 12 May 14 @ 4:46 pm
Have changed it to icecast MP3 128Kbps, then changed it to PC-TO-PC again.. and sending to http://www.virtualdj.com/homepage/djay7/broadcast.html
Djay_7 wrote :
I can only use shoutcast there... doesn't work with icecast on the free hosting...
What if you change the settings in the VDJ config?
config -> options
select advanced
search broadcast then change
broadcastDirectFormat to MP3
Posted Mon 12 May 14 @ 4:47 pm
OK, changed the settings now... why they are not in the broadcast tab I will never know.. lol
Posted Mon 12 May 14 @ 4:49 pm
Your running - i can here you!!
In that case.. I will make the most of it and play you all some tunes for a little while lol ;) Many thanks for your help and I hope you enjoy :)
Posted Mon 12 May 14 @ 4:50 pm
No worries mate - glad we got it sorted.
windows 7 vms4.1 and i am trying to stream not podcast or pc to pc i use a streaming service that i use to stream thru i can switch back to vdj 7 and i can broadcast fine. but i am getting erro's. when i switch to vdj 8
Posted Mon 12 May 14 @ 5:09 pm
DAN... can you make this into a sticky thread please
Posted Tue 13 May 14 @ 2:00 am
djtouchdan wrote :
Thanks - yes I checked it today on my iMac and found the stream working ok but I'm not getting the delayed play from iTunes or Winamp on my Win 7 machine that I get from VDj 7 and that tells me my stream is running..
Posted Tue 13 May 14 @ 5:01 pm
my shame at not being as good a geek as I thought I was is showing.
win8. how do I open port 8000?
been itching to try the broadcast feature all day.
Posted Tue 13 May 14 @ 9:36 pm
This might help for starters mate:
http://www.virtualdj.com/wiki/Broadcasting%20Howto.html
Posted Tue 13 May 14 @ 10:07 pm
it didn't.
(edit.. again..)
so according to this they are already open?
(edit.. again..)
![](/image/76306/135171/8000.jpg)
Posted Tue 13 May 14 @ 10:12 pm
I usually stream it is one of my my activities for more than 6 years. After install VDJ8 and check the procedures to set up for broadcast I had a normal gig. Even i had the chance to check up with diferent listeners and everything was ok ...
Posted Wed 14 May 14 @ 5:40 am
wildcountryclub wrote :
it didn't.
(edit.. again..)
(edit.. again..)
You should make sure that the port is opened for UDP protocol.
It could also be necessary to allow port-forwarding in your router.
How that could be done is diffrent from router to router.
Just google for it with your router type.
Posted Wed 14 May 14 @ 5:45 am
