I tried to use my Denon MC6000 with VDJ 8, the software keeps rebooting itself. My controller has the latest firmware....any ideas?
Posted Sun 11 May 14 @ 11:41 am
I have the denon mc 6000, but i have not tried to connect it yet, will be doing it today sometime I'll post back how it goes. Check out this post and see if it helps you at all. http://www.virtualdj.com/forums/187106/VirtualDJ_8_Pre-Release_Forum/Problem_with_Virtual_8___Denon_MC_6000_(Original).html
keep em dancing
keep em dancing
Posted Mon 12 May 14 @ 12:18 am
re-map your fx sliders and fx btn
then your good to go :)
Posted Mon 12 May 14 @ 12:29 am
Some of the effects were not compatible. I deleted the effects in question and now everything is good!
Posted Mon 12 May 14 @ 8:53 am
