Topic: [NEWS] VirtualDJ 8 Pre-Release - Page: 8
stevelebo wrote :
VDJ 8 NEED HELP!
1. Video effects why is there NO text option...( I installed text2d and it does not work properly in vdj8). I have NO camera option either...) Why so few video effects?
Virtual DJ 8 is currently in Pre-release. The main reason for this was to obviously test with a wider audience, but also give plugin developers the chance to update their plugins for V8.
stevelebo wrote :
2. I have Numark Cue PRO, and I understand this is a FREE upgrade to all pro users, so why can I not remove logo...(It says I need to upgrade)
http://www.virtualdj.com/products/legacy.html
stevelebo
I also have numark cue virtual vinyl pro and i just had to pay for the upgrade $49 they told me that numark is not upgrading to virtual dj 8
Thanks guys,
Off to download now.
In The New Version V8 Reads Many Innovations
But Do Not Read The Principal :
To Improve Its Engine Beatmatching
Which Is Outdated In Relation To The Competition .
Even DJ Applications For Handheld Devices Tablets Ipad
[ Djay From Algoriddim / Cross Dj ]
They Have More Reliable Beatmatching .
The Virtual Dj . V8 This Will Improve ?
@1439FM I think you've been using it wrong mate, with a minor correction of the CBG, VDJ is solid on beatmatching and it has been for years.
Of my 10,000 tunes I've probably had less than 100 tunes where the CBG was wildly wrong and I have a lot of breakcore in the 210+ bpm range.
I just installed VDJ* and did some more testing. I put the same video on each player and the B is twice as bright as A side. Any idea?
Thanks For Your Response ! - locodog
I Do Not Mean Not Working Well
The Beat Maching In Virtual Dj .
You Just Might Be Further Improved .
There Are Songs That Are Not Synchronized So Well
As In Other More Sophisticated Applications
Traktor / Serato But Even The
Djay 2 From Algoriddim & Cross Dj
That Are For Portable Use Synchronizes Firmer.
The Virtual Dj Has About Upgraded
Basically 3 Years
Besides Is Strange Why They
Is No Reference To The Beat Maching
Sorry For Not So Good English .
My bad. Figured it out. Thanks
Will vdj8 load up up side by side of vdj 7 and I assume both will run on the same laptop each with its own icon and separate program using the same database???? Just want to be sure before I load it on my show laptyop. Don't want to install one program over the other if there is interference between there files?
hi people, when you put playlists from version 7.4 to version 8
all the songs are not in the right order
is this happening to any body else
@bryantpb they are different programs so you'll have both but the smart thing to do is backup the V6 database.xml before installing
Known issue that is already reported to the Dev Team....
I´m shure there will be a solution.
how can one be able to get the pre realese?
if you own a legal and registered licence of VDJ Pro Full you have access to download the pre-release version.
Buy a pro copy of VDJ 7 now and then register it ...... and then you can join us all working to make V8 the best version ever :-)
VDJ7 Pro Full is no avaliable anymore, you can only upgrade to V7 possibly as long as as there is the pre-release running, owing a Pro Full Licence already.
You can only buy VDJ Pro Infinity if you want to join the pre-release testing of having all features ( and more) from the former VDJ 7 Pro Full.
VDJ 7 Pro - VDJ Pro Infinity ........ Tomato - Tomato :-)
5 hours at the club last night mixing video and no issues .....fingers crossed , sound is much wider with more punch
hi peeps, making playlists in version 8 but when you go back to playlists there not in the right order
You need to report things in the pre-release forum.
86%
