can some one help ive got new virtual dj 8, don't mean to be thick, but how do you make playlists
Posted Tue 13 May 14 @ 3:24 am
Please do not post the same message in multiple locations. It's against the forum rules.
Posted Tue 13 May 14 @ 3:39 am
the great thing is reading the manual shows you a lot. I set the manual on one screen and vdj 8 on another, so i can get used to it. there is so much to this new program, I know i don't want to miss anything.
getting the logo off is in config, video then click on advanced and say no to logo..
Posted Tue 13 May 14 @ 7:05 am
Okay take one of your playlist and drag it over to the right of your screen , where you can open the sideview , drag the playlist folder into there . now take a song a drag it anywhere you want , it automatically saves .
Posted Tue 13 May 14 @ 8:02 am
Thanks to the team of VDJ for the realization of Virtual DJ 8. Done a great job, well done guys. Everything works fine on my laptop.
Posted Tue 13 May 14 @ 8:23 am
hi guys, my question is, because my hercules rmx, does not work or is not control any buttons or jogwheel, only shows me the audio outputs but with a red x at the end, please help
Posted Tue 13 May 14 @ 8:48 am
PLEASE PLEASE PLEASE
Can technical questions regarding the Pre-Release of Virtual DJ 8 be reported in here : http://www.virtualdj.com/forums/75/VirtualDJ_8_Pre-Release_Forum.html
We have the beta testers regularly checking the forums to assist as well as the development team picking up on issues. Having posts everywhere is confusing.
Thanks for understanding. :-)
Posted Tue 13 May 14 @ 9:14 am
awesome.
Posted Tue 13 May 14 @ 10:09 am
groovindj wrote :
Change the sampler layout to list view, then click the edit button (gear icon).
There's no way of switching them directly (from either mode/view) like there was in V7.
Thanks, I figured it out about an hour after posting my question, lol! and you can input way more than you ever could with clip bank this way. I gotta say, I'm kinda lovin VDJ8 so far!
Posted Tue 13 May 14 @ 1:01 pm
cnt wiat for this to release,just which the word size were a little bit bigger
Posted Tue 13 May 14 @ 1:12 pm
On the bottom left hand corner there are 2 buttons to enlarge or shrink the text
Posted Tue 13 May 14 @ 1:15 pm
Nice job Atomix team...looking forward to giving it a go.
Posted Tue 13 May 14 @ 2:40 pm
Thank you VDJ Team. Nice look and I will definitely check it out. FLeX
Posted Tue 13 May 14 @ 5:07 pm
How do I make SONIQUE trans from one to another on audio file only?
Posted Tue 13 May 14 @ 9:24 pm
Check out the owners manual that installed with the program.
The option is videoaudioonlyvisualisation, I believe it's an advanced option.
Posted Tue 13 May 14 @ 9:57 pm
Thanks God
Posted Tue 13 May 14 @ 11:32 pm
has anybody try virtual dj 8 with timecode record i try it but i have numark virtual vinyl pro and it only give me ten min to play with it .there a delay for the ten min i play with it i like to scratch i guess i have to wait to upgrade to virtual dj 8 infinity can anybody let me know if there are setting to make the scratch tighter
Posted Wed 14 May 14 @ 1:16 am
Make shure that you have the necessary directX9 drivers installed and set sonique as plugin for videoAudioOnlyVisualisation in options
Posted Wed 14 May 14 @ 1:17 am
Infinity would be what your using. It's just pre-release. There is some timecode talk here:
http://www.virtualdj.com/forums/187224/VirtualDJ_8_Pre-Release_Forum/Timecode_users_________.html
I'm using it with CDJ's and the response is great. I don't have the ability to scratch, so I cannot comment on drift and tightness myself.
Posted Wed 14 May 14 @ 1:27 am
AFAIK that's not possible at the moment. Just one effect at a time until you manually choose another one.
But have a look at here
http://www.virtualdj.com/forums/187422/VirtualDJ_Plugins/Milkdrop.html
Posted Wed 14 May 14 @ 2:05 am
