Forum: Old versions
Topic: I Need Help With Timecode set up
I have recently got a numark cd dj in a box bundle and a american audio vestaport soundcard and im running virtual dj 7 pro with vdj timecode cds. my problem is that the song isnt playing although the timecode is. I have checked to make sure everything is plugged in correctly and that the drivers were up to date and i got the system working but now it seems not to play. what can i do.
Posted Fri 18 Apr 14 @ 7:20 pm
Have you tried the steps in the manual?
You can also check out the wiki here:
https://virtualdj.com/wiki/TimeCode%20Config.html
Register your pro serial number to check your version of pro against the one that will be in your download center to make sure you have the current version.
