Hi. Is it possible to change effects, which i can launch from xdj-r1 by default (i mean in virtual dj when pressing flanger, echo and roll button from controller i woul like didfferent effects )
thanx
thanx
Posted Wed 09 Apr 14 @ 5:30 am
Not with LE versions. If you upgrade to PRO FULL then you can.
Posted Wed 09 Apr 14 @ 7:09 am
Hi all, please your help with these questions:
1. In MIDI mode (VDJ) can be used remotebox (to control effects with the ipad)?
2. Mixer Mode, specifically in PC mode, work properly "sound FX Color" and "Beat FX"?
Thanks...
Thanks...
Posted Fri 11 Apr 14 @ 6:23 pm
i have Pro full version - how can i do it there ? thanx
Posted Tue 15 Apr 14 @ 9:21 am
