Hello -
My Hercules RMX Controller is no longer being recognized on my MacBook Pro, running OS 10.9. I just installed the latest drivers from Hercules, and that still is not fixing the issue. Whereas before when I would open up Virtual DJ Pro 7 my RMX would pop right up in the configuration menu, it's no longer there. I'm still getting blinking blue lights, but none of the buttons/sliders are working.
Word on the street is that a powered USB may help - I ordered one, but something tells me that might not fix the issue. Anyone else having this issue or have any suggestions?
Thanks,
Benjy
Thanks,
Benjy
Posted Mon 07 Apr 14 @ 2:13 am
Have you installed the latest driver from Hercules and are you sure you use the latest pro Full from your VDJ account?
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=215&cid=1
and
https://virtualdj.com/users/edit.html
PS:You need to register your Pro Full licence before there to see the Pro Full :-)
and
Posted Mon 07 Apr 14 @ 8:11 am
Did you ever find the issue with you RMX controller? I am having the same issue.
Posted Fri 25 Sep 15 @ 12:36 am
