Topic: 24 hour clock - Page: 2
djtouchdan wrote :
funkmasterfrank wrote :
Using the default skin by clicking on the clock it doesn't work with every laptop.
It has absolutely nothing to do with the laptop. It is down to who ever designed the skin and how they implemented the code.
blckjck wrote :
....Then it would always be 12 hr., no clicking needed.
Correct, best bet is just move the option you want to the top of the list, then the over options are there (just in case):
<textzone>
<size width="x" height="x"/>
<pos x="x" y="x"/>
<text font="arial" size="12" align="center" format="%hour12"/>
<text2 font="arial" size="12" align="center" format="%hour"/>
<text3 font="arial" size="12" align="center" format="%fullhour"/>
</textzone>
If you copy and paste the bit in bold into the <textzone> in the skin you want to modify you'll be good to go.
As as Groovin' said - all in the XML.
This is frickin B E A Utiful!! Thank you everyone and Thank you very much DJDan for the code. I changed the font size to 16 and it works great. I even found where the key of the track is and changed that so it would show the Camelot system first.
Brendan
