Hi Guys,
i have the Hercules DJ Console RMX 2 and im thinking to go to the Hercules DJ Console RMX 2 Premium TR MIDI-Controller, the main reason is because an idiot spielt 1 full glas of cola on it..and now is working "funny"
now the question..
does it work with Virtual Dj as good as with Traktor?
im not a big fan of Traktor but i have been told that the consol is build for Traktor and im just scared that it will not work so well with Virtual DJ as it use to do with the DJ Console RMX 2
what do you think?
and now that i have your attention :-p
what would you recomend DJ Console RMX 2 Premium TR MIDI-Controller or the DJ CONSOLE 4MX?
i see as pro for the 4mx that the jogwheels are bit bigger.. but im afraid that the sound quality is not the same.. any tips ideas?
thanks!
now the question..
what do you think?
thanks!
Posted Fri 14 Mar 14 @ 10:06 am
Beside the black overlay, yellow knobs and provided bundle, the Rmx2 Premium it is the exact same controller, so it will work the same way with Virtual DJ.
If you are already comfortable with the Rmx2 and its features (the pads, layout and such), I woud recommend sticking with it.
Posted Fri 14 Mar 14 @ 1:42 pm
Thanks!!
Posted Sat 15 Mar 14 @ 8:07 am
dont forget you can use it and add on other effect controllers. I have 6 controllers running at once
Posted Sat 15 Mar 14 @ 11:33 pm
