Vestax VCI-380
Forte dell’esperienza fatta con i precedenti modelli della serie VCI (a partire dal primo storico modello VCI-100) Vestax presenta la VCI-380: una nuova console professionale 2+2 decks midi dotata di scheda audio e mixer vero; sarà infatti possibile utilizzare gli ingressi audio per collegare e mixare fonti sonore provenienti anche da giradischi e lettori CDJ.
More info -> http://www.vestax.com/v/products/detail.php?cate_id=189
Recensione -> http://www.digitaljockey.it/dij/maglog/recensione-vestax-vci-380/
Mapper avanzato per VirtualDJ PRO -> http://it.virtualdj.com/addons/16581/Vestax_VCI-380_Advanced_Map.html
Posted Sat 08 Mar 14 @ 3:05 pm
Ecco il video con la spiegazione del mapper linkato sopra ;)
Posted Wed 19 Mar 14 @ 12:36 pm
Hello. I recently purchased a VCI380, and in the past week Vestax has taken down their website. I am tyring to find a download for the VCI380 Audio driver, but all of the websites i have searched on google redirect to the Vestax support website (which no longer is active). --Do you happen to have a copy/file/zip of the audio driver file for the VCI380? I am using Windows 7 64 bit. I would be extremely grateful if you could find this file for me! Thanks for your help. I am really happy to using be my Vestax unit.
Posted Tue 02 Dec 14 @ 12:27 am
Please don't cross post!
http://it.virtualdj.com/forums/187789/VirtualDJ_8_bug-report_Forum/VCI-380___Virtual_DJ_8.html
Vestax website is temporary down.
Posted Tue 02 Dec 14 @ 1:44 am
Disponibile il mio mapper avanzato v2.0 per VirtualDJ 8 ;)
Download -> http://it.virtualdj.com/plugins/index.html?addonid=80236
Topic -> http://it.virtualdj.com/forums/200213/Addons/Vestax_VCI-380_Optimized_Mapper.html
Posted Tue 21 Apr 15 @ 4:26 am
