Hi, When using a dj controller everything works fine except for the cue and master on the controller. They just wont work/respond whatsoever.
Anyone familiar with this or know what to do? Thanks!
Posted Sat 28 Dec 13 @ 1:50 pm
What controller? The controller will only work with the LE version, that came with the controller. If you have a LE version that came with a Hercules controller, it will not respond with a Pioneer controller.
Posted Mon 30 Dec 13 @ 4:05 pm
He's got a DAP D2 according to his icon, which is a.k.a. DAP Core Kontrol D2.
Wolffmann, when you say those controls won't work, can you be a bit more specific?
In the case of the master volume, are you saying that there is no sound output from the master out of the DAP D2?
Which cue are you referring to? There are lots of controls marked cue on that controller.
Posted Mon 30 Dec 13 @ 4:46 pm
