Updated ver 1.01
- Fixed jog rotation spinner
- Added Split headphones button Output panel)
- added TC buttons (Input panel , labels L & R)
Yes, there will be a 4 Decks version, just cant tell when.
DJLokke wrote :
@ Djdad, will there be also a 4-Deck-Version?
Posted Wed 21 May 14 @ 4:24 am
Babis, can you update this skin so that there is a "grab zone" on all edges of the skin, not just the top?
One user has managed to get the top edge off screen and cannot drag it back because it's not possible to grab the side or bottom.
Posted Wed 21 May 14 @ 10:04 am
good call, will do shortly
EDIT. Added. Version 1.02 is now available.
Wasnt hard at all ;)
Posted Thu 22 May 14 @ 4:18 am
I know this skin is called multi fx but where are the effects on the skin and how do you select them?
Ignore that found it now :-)
Posted Thu 22 May 14 @ 8:04 am
Please, I haven't :D
Posted Fri 23 May 14 @ 5:27 am
Posted Fri 23 May 14 @ 5:36 am
Won't show, I have blank space and clicking on "1/2/3/M" or the dots beside either won't do anything or will crash the software
Posted Fri 23 May 14 @ 6:13 am
Yes, there will be a 4 Decks version, just cant tell when.[/quote]
Hope very soon, because i am working normaly in a 4-deck-mode and i like this new 2-deck-version of the Skin ;-)
Posted Sat 24 May 14 @ 1:53 am
Any chance a Master Volume knob could be added to the skin, vdj runs so loud and I always have to switch to the stock skin to turn down the master it would be great if I didnt have to.
Posted Sat 24 May 14 @ 10:30 am
You mean the one to the left of the config button?
Ah, that was on the old version.
Posted Sat 24 May 14 @ 1:29 pm
Great skin, DJ Dad. Can't wait for the 4-skin update you have planned--oops, I mean 4-deck version. This may sound trivial, but I got to tell you how much I like the track cover art being placed on the platters--VERY NICE. It's not only aesthetically pleasing but this feature also serves important practicality for having enhanced view and management of your music as it is playing, especially when mixing on a 3rd and 4th deck. Big thanks.
Posted Sat 24 May 14 @ 7:46 pm
I just discovered with version 1.02 that the cover art on spinning platter feature isn't working with this recent update of MultiFx Skin. I will retest to make sure.
Posted Sun 25 May 14 @ 2:23 am
Hello DJ Dad,
I have a question: fix your skin "Dark Minimal X-Wide 1.1" for the vdj8?
About it I would be very happy ;-)
Sorry for my english, translate with Google ;-)
Greetings from Berlin DJ Nick
Posted Sun 25 May 14 @ 5:48 am
Click on the "eye" icon on the top-left side of the skin and choose to view the Output panel
Posted Sun 25 May 14 @ 6:28 am
It works here...
Posted Sun 25 May 14 @ 6:30 am
djdad wrote :
It works here...
It works here...
Thanks, DJ Dad.
Posted Sun 25 May 14 @ 9:44 am
Hi & big thanks for this,
but
got the same prob right here. Working on mac with 1440/900 resolution (build 1806):
A liitle bug appears on the left side with the scratch waves (start point is in the magnifier).
OT:
Is there a wiki for the new skin-engine? Can't find it..
Greets from Germany
Music234
but
OT:
Greets from Germany
Music234
Posted Sun 25 May 14 @ 1:11 pm
Blank Efx section +1 MacBook Pro Retina , osx v10.9.3
Posted Sun 25 May 14 @ 4:38 pm
@music234, are u on a Retina Mac as well ?
Btw, since someone mentioned something about dots, its the buttons 1,2,3,M that u need to click, not the dots next to them. Those are just to prioritize a unit, if more than 1 is visible inside the rack.
Posted Sun 25 May 14 @ 5:29 pm
I got no Retina, do you need the specifications?
BTW:
I'm kind of ...., right side the scratch wave; sorry ;O)
BTW:
Posted Sun 25 May 14 @ 5:41 pm
