Hi I recently purchased an dj Tech X10 to use with a Vestax Vci- 100. I tested it at a party and it worked fine for about 2 hours and then my SYNC button began to stick and malfunction. Whenever I loaded a new track it would force the playing track to change BPMs in real time... not good! the pitch sliders became stuck as well.
the only solution was to reboot my laptop.
Anyone ever heard of this problem or has an idea how to fix? I really like this mixer and would hate to return it...previously I used the Maya 44usb which works great -.
thanks
djrelight
thanks
djrelight
Posted Sun 17 Nov 13 @ 9:54 pm
I'm trying to use my x10 with VDJ Pro. I have 2 Rane midi controllers, but after setting it all up I can only get one controller to work and if I use both sides they only play out of my A side on the cross fader. What am I doing wrong?
Posted Sun 03 May 20 @ 10:36 pm
You're not providing enough information.
How have you set it all up? What hardware connections/VDJ audio settings?
Posted Mon 04 May 20 @ 4:25 pm
