I have DirectX 11 installed on my laptop (Windows 8) and I'm trying to install the Text2D plug in, but I keep getting the "d3dx9_32.dll" error when I click on it when VDJ is open. Anyone have an update on this? I assume the plug in wasnt designed for Windows 8 or that high of DirectX. Thanks all!
Posted Mon 11 Nov 13 @ 6:59 pm
Read the sticky at top of page, you need to install dx9, it's all in the sticky...
Posted Mon 11 Nov 13 @ 7:40 pm
Thank you sir! Got it working! :)
Posted Tue 12 Nov 13 @ 8:06 am
Hi I have installed text2d and the missing file required, when I open text2d it opens fine, buy talking to a friend it seems I have "Apply" and "Apply plus activate" buttons missing so it will not work? Any ideas please?
Posted Wed 28 May 14 @ 10:26 am
If you are running Virtual DJ 8 then this plugin needs to be updated in order to work correctly.
This will be down to the original developer of the plugin.
Posted Wed 28 May 14 @ 10:40 am
This will be down to the original developer of the skin.
TYPO: of the plugin,not the skin Dan....;)
Posted Wed 28 May 14 @ 4:58 pm
