I've notice when using the dump command the channel effected goes out of sync
I'm running 7.0 pro B342
*edit* What I meant to say is when I exit the dump the tracks are no longer aligned, I have to nudge the dumped track forward.
I think some thing like
<map value="RETURN" action="dump ? dump & nudge +Xms : dump " />
Should sort it but I don't know what X should be, I could use trial and error for the solution, but I thought I'd bring the problem to the VDJ tech's attention
Posted Fri 04 Oct 13 @ 1:51 pm
Best thing to do is register your serial and download the current 7.4 version.
Unfortunately support won't answer queries on older builds as many things have been changed since the version you are currently using.
Keith
Keith
Posted Fri 04 Oct 13 @ 2:59 pm
