Forum: Old versions
Topic: Playlist song order problem
cnymikePRO InfinityMember since 2011
I create playlists with a specific song order in mind. As I create a lengthy playlist, occasionally I accidentally hit the Artist or Title heading and my playlist instantly gets borked. Is there any way to restore the order I had before i accidentally hit the Title or Artist heading? I know that if i'ts been saved, all I would have to do is reload it. but this is before it gets saved.
Posted Mon 26 Aug 13 @ 9:28 pm
Unfortunately this is not possible. Clicking on one of the headings will permanently change the order of the files.
If you are creating a large new playlist, then saving it at regular intervals as you create it is recommended (E.g: After every 25 songs you add.)
Posted Tue 27 Aug 13 @ 4:26 am
