Hi there,
I had a cache of over 300 songs and when I moved them off my hard drive and then moved them back to the VirtualDJ>Cache folder, they would not show up in VirtualDJ and I cannot get my files back into the program.
I would like these files to show up in the "show content downloaded" folder under the "content unlimited" section however they will not show up.
Only the new songs that I save to my cache will show up in the actual program.
Doesn anybody know how I can get all 300 songs back into the program so I can view it under the "show downloaded content" folder?
Thanks in advance,
Patrick
Thanks in advance,
Patrick
Posted Thu 11 Jul 13 @ 2:45 am
So they are at the sam position then before?
Are you logged in at VDJ Config - Internet?
To avoid any problems with expired files, you should refresh your cache authorisations right now.
This will ensure that everything is up-to-date: http://www.virtualdj.com/wiki/ContentUnlimited%20Offline%20Use.html
A nice Topic about that all is here too.
http://www.virtualdj.com/forums/160109/Premium_Members_Forum/_Help__-__to_refresh_the_cache_.html?search=refresh&page=1
Posted Thu 11 Jul 13 @ 3:13 am
If you have moved the files to a different location, then you will need to add them to your VirtualDJ database again.
Use the VirtualDJ browser to browse to the folder where they are now located, (E.g: My Documents -> VirtualDJ -> Cache ) and then right-click on it and choose Add to search DB.
Posted Thu 11 Jul 13 @ 5:45 am
