Hi
My crossfader works going side to side but it doesn't fade its either fully on or off..
The mapper setting is
Crossfader action crossfader
There are no figures to tell it to fade out etc
Is something wrong?
Im using hercules air
Thanks
Is something wrong?
Thanks
Posted Thu 30 May 13 @ 3:48 am
You could also use the mapping file provided on the Hercules Support site:
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=287&cid=10
Posted Thu 30 May 13 @ 5:46 am
Thanks but I downloaded that and am using it but the file has the same code for the crossfader
Could it be doing this if in scratch mode or am I missing the action text?
Posted Thu 30 May 13 @ 5:50 am
Check the Crossfader setting in CONFIG -> Options (Click on it to cycle through the available crossfader curves.)
Posted Thu 30 May 13 @ 7:39 am
Ok thankyou I'll let you know
Posted Thu 30 May 13 @ 8:48 am
