Hi guys,
I bought my hercules rmx about two years ago but I stopped djing for a while and now I've decided to try to pick it back up. I just installed my hercules drivers and Virtual DJ 5.22 LE (the software that came with the hercules). Everything has worked fine but the cross fader doesn't seem to be working properly. Virtual DJ recognizes the cross fader and moves it on the screen as I move it on the console, however, it doesn't change the sets. Moving the crossfader to the right won't play the song on the right. The only way I can move from deck to deck is by using the cue select button. The crossfader plays no role. How do I fix that? Sorry if this is a stupid question.
Thanks
Thanks
Posted Sun 26 May 13 @ 10:03 pm
Make sure your speakers connected to Output 1-2.
If the are connected to output 3-4 (which gets the same signal as the headphone output) it is perfectly normal that the CUE Select buttons will dictate what you hear.
Posted Mon 27 May 13 @ 7:03 am
