Forum: Old versions
Topic: help with samples please
Hi guys, i've just downloaded some samples from the site but cant seem to find the folder they need to go in to run them.. help please thanks
Posted Sat 04 May 13 @ 4:18 am
The exact location depends on the OS you're using.
On Windows 7 the VDJ folder is under C:/Users/yourlogin/My Documents/Virtual DJ/
The yourlogin part will of course be whatever your user account name is, not literally yourlogin.
Once you're there, the location should be pretty obvious.
On the other hand, you could just open the sampler tab, and select 'load' on one of the slots, which will open the sample location.
Posted Sat 04 May 13 @ 6:09 am
