So I just picked up a mixtrack pro and connected it to VDJ Pro. everything works fine except for 2 things:
1. the crossfader doesnt work at all. if i adjust it on the computer it works but the one on the controller is unresponsive. and when i adjust my deck 2 volume on the controller, it slightly moves the crossfader over to the right.
2. i tried connecting my desktop speakers to the soundcard using a splitter, and all i am hearing is all treble and only out of the right speaker. I have configured my audio setup correctly (i found out the configurations by searching online) but still no luck.
can anyone help? thanks!
Posted Tue 23 Apr 13 @ 7:33 pm
First make sure you have the latest version.
You can register your Pro serial number on the page http://www.virtualdj.com/users/edit.html and then download the latest version from the Download Center: http://www.virtualdj.com/download/updates.html
The wiki has the settings and cable connection info..
http://www.virtualdj.com/wiki/MixTrack%20Pro.html
You do not need to use a Y adapter with the Mixtrack Pro since it has RCA outputs on it.
Posted Wed 24 Apr 13 @ 5:56 pm
