Well thats the beauty of VDJ, you could easily add those to any skin you use. Give it some time and I sure some skinners will be adding these soon, if not already in the works...
Posted Sun 24 Mar 13 @ 1:47 am
lucas569 wrote :
also the genius dj no longer exists, when i hit recommend (this actually came in very handy) it shows NOTHING
It's still there but it's now called Livefeedback?
There's a tick box in Config/Browser
Posted Sun 24 Mar 13 @ 6:29 am
@sonance make your vinyl mode button on your controller flash when slipmode is active eg.
holding 500ms ? slip_mode on ? blink 300ms & slip_mode off : slip_mode on & vinyl_mode on : slip_mode on ? slip_mode off : vinyl_mode
that way you can activate slip mode if you hold the button for half a second, to get out of slip mode you can either hold the button for a half a second or press it twice to go from slip to vinyl to normal. holding the button for less than half a second will activate/deactivate vinyl mode as normal
Posted Sun 24 Mar 13 @ 6:35 am
nice one, synth. i was thinking of using the vinyl button on my vci400 as well, but haven't installed 7.4 yet. i'm patient. hehe. probably map the loop_roll to a mode button below the button grid and use the grid for loop control.
Posted Sun 24 Mar 13 @ 11:29 am
Where is the 7.4 download link?
Posted Sun 24 Mar 13 @ 3:08 pm
Never Mind, I found it.
Posted Sun 24 Mar 13 @ 3:12 pm
I had gig last night for 11 hrs. And guesss no problem.............. Ready to up grade thanks Atomix good good Job
Posted Sun 24 Mar 13 @ 4:47 pm
Tjeck1972 wrote :
Hi all
Reseting all with Registry tool, uninstaled ver. 7.3 and instaled ver 7.4. Deletede all old mappers for DDJ-SX. Switched unit to Serato mode.
Decks actions are working well, but mixer part is not working at all.
Only CUE button on deck 1 lit. Any action a can see on VDJ display but nothing happen on DDJ-SX.
Using DDJ-SX driver ver. 1.000
DDJ-SX firmware 1.05
Thank you Tomas
Thank you Tomas
I am having the same problem here. I never installed the previous mapper as I was running my DDJ-SX with Serato DJ until it is natively supported by VDJ. So there is no mapper to delete.
But with the 7.5 upgrade only the play/cue and load functions are responding. Mixer sections has not response at all. Matter of fact both decks play out of the master even of my fader is all the way to the left/right and the up fader are down to zero.
Posted Sun 24 Mar 13 @ 4:58 pm
I know one shouldn't install updates before gigs, but I couldn't wait to try out the 3700s @ 2960 cycles. All is well so far. THANKS TEAM!!!
Posted Sun 24 Mar 13 @ 5:02 pm
I've just been looking at Traktor's 'flux' mode
That seems quite easy to map, albeit still not as good as it could be
I don't get why lots of these great features aren't built into the default skin
ie. a button to turn on/off slip and a knob for loop roll
these features are often buried away and only accessible if you know how to mess around with the scripts
- or maybe this feature will be more visible in v8?
...watching and waiting....
Posted Mon 25 Mar 13 @ 8:10 am
Thank you for this video.
Looks like it respond really well @2960.
Can you see a good difference from 1480 ?
Posted Mon 25 Mar 13 @ 8:50 am
