Forum: VirtualDJ Skins
Topic: Hercules 4-mx: anyone has the same problem as me?
Hey all
Several months ago, i used Hercules 4-mx skin to set my effects as i wanted.
After a few months not touching my 4-mx, i came back to see everything was set to default, meaning vdj was like the first time i used it.
So i downloaded the 4-mx skin again to set my effects again only to find out that i can only change the effects on the right deck but NOT on the left deck.... Weird.
Asked the maker of the skin about this but I just wanted to know if anyone else has the same problems, or is it only me?
Grtz Stievie
Posted Wed 13 Mar 13 @ 5:13 pm
AM I really the only one who has issues with this? Or does noone cares about this skin....
I have the smae problem. Bene trying to disect the skin.xml file to fix it. if you change to a lower resolution, the effects come back.
-josh
