Hey Ladies and Gents
I'm having a issue with getting my Mix Track Pro 2 to work with Vitural DJ Pro (Full) Ive configured it how It was show to do, yet it still doesnt work with my Mixtrack Pro 2, Question im asking how do I get it working and is vitural Dj Work with Mixtrack Pro 2, NOT Mixtrack Pro 1. Many thanks
Z, Bredin
Z, Bredin
Posted Thu 28 Feb 13 @ 12:33 pm
The Mixtrack Pro 2 is a brand new product, so at this stage there's no mapping supplied with VDJ.
However, if you check the MTP2 product page on the Numark web site, there's a VDJ mapping available to download.
Posted Thu 28 Feb 13 @ 1:02 pm
i have the same midi controller numark mix track pro 2 and just i can get mappings for traktor but i need for virtual dj the version i have is virtual dj 7 pro
and i need to record a mix or the mixes i can need for that
some help for this please
i asked in westend dj in the shop i´ve bought and them said i can make running with virtual dj 7 pro
but the question is how can i do this thank you
Posted Fri 12 Apr 13 @ 6:47 am
Read my previous message! The mapping is on the Numark web site.
If you're using VDJ Pro you should register your serial number here, so that you can download updates, mappings, plugins, etc.
Posted Fri 12 Apr 13 @ 6:56 am
Thanks for the note groovindj. We have been looking at purchasing this controller and I wanted to make sure there was mapping available before purchasing.
Thanks!!
Thanks!!
Posted Wed 08 May 13 @ 5:45 pm
Posted Fri 24 May 13 @ 1:12 am
Can you download the mappings for the numark mixtrack pro on the virtual dj home software.
Posted Fri 24 May 13 @ 7:41 am
VDJ Home doesn't support controllers.
Posted Fri 24 May 13 @ 8:23 am
I just purchased the new MixTrack Pro2, and I assumed that VDJ would support the Pro2 because it supports the regular Mixtrack and the first Pro. So I don't understand why VDJ doesn't support Mixtrack Pro2. I feel stupid because I bought it, and I hate Serato, it is so confusing. If VDJ is going to support the Pro2 then why is it taking so long, and when is it going to happen?
Posted Mon 05 Aug 13 @ 6:57 pm
Mixtrack pro 2 is supported in VDJ. You just need to have VDJ Pro. You can use your discount from the first mixtrack you already have registered on your account, and upgrade.
Posted Mon 05 Aug 13 @ 7:12 pm
As above the Numark Mixtrack Pro II is natively supported with the latest Pro Full version . https://virtualdj.com/wiki/VirtualDJ%20Controllers.html
the LE version of VirtualDJ that came bundled with your old Mixtrack will only work with that unit and no other. You will need to upgrade your LE version at a discount https://virtualdj.com/products/oem.html . Yu can test your controller with VirtualDJ Home Free version https://virtualdj.com/download/free.html prior upgrading. Home Free version will work with your controller for multiple 10min sessions.
Posted Tue 06 Aug 13 @ 7:53 am
I just bought a Numark Mixtrack Pro 2 controller and it came with Serato which I totally dislike. The Virtual DJ Home Free edition that I have will not work with the controller I bought. It says I need the PRO version. will VirtualDJ Pro Basic work or do I need the VirtualDJ Pro FULL?
Posted Fri 18 Oct 13 @ 10:42 pm
Only the full VirtualDJ Pro supports using controllers: https://virtualdj.com/buy/
All other versions are for mouse/keyboard only, except for VirtualDJ LE that's included with selected hardware and will only work with the hardware it's included with. Please see https://virtualdj.com/products/comparison.html
For further assistance, please contact support: https://virtualdj.com/contact/
Posted Sat 19 Oct 13 @ 11:03 am
Hello, I have Numark Mixtrack and I saw that I can download extra effects and I was wondering how I insert them into my software. I am just getting started and was wondering if you guys could help me.
Thanks.
Thanks.
Posted Mon 21 Oct 13 @ 6:33 pm
Posted Tue 22 Oct 13 @ 6:04 am
How much is the upgrade from LE to Pro?
Posted Thu 24 Oct 13 @ 12:54 pm
It depends on what product you are upgrading from.
You can find out by going to https://virtualdj.com/buy/ and entering your VirtualDJ LE serial number in the box provided.
Posted Thu 24 Oct 13 @ 1:06 pm
I am ordering the Mixtrack Quad (retail price~ $399.99) do you think you could tell me the upgrade from le to pro?
Posted Fri 25 Oct 13 @ 7:12 am
I Connot Download A Skin of Numark Mixtrack Pro 2... Can U Pass The Website..Thaks
Posted Sun 27 Oct 13 @ 9:56 am
Please read our FAQ pages:
https://virtualdj.com/wiki/How%20do%20I%20download%20and%20install%20new%20plugins.html
Once you have purchased and/or registered your software, a skin can be downloaded from https://virtualdj.com/addons/16139/Numark_Mixtrack_Pro_II.html
NOTE: Please DO NOT ask users to send you add-ons to which you are not currently entitled or your account will be locked.
Posted Sun 27 Oct 13 @ 11:49 am
