That's just the way things are, nothing stays the same. However, you can still use 7, if it's that important.
Posted Tue 19 Jan 16 @ 4:28 am
dodgebullitt wrote :
Why remove it though? it was an awesome function in 7 ???
And, it's not really a function that was removed. It's just a filter folder that you can create.
The "My Library" "plugin" has a large number of filter folders to help navigate your library. Plus there are quite a few examples in this thread alone.
Posted Tue 19 Jan 16 @ 5:45 am
Create a Compatible Songs Filter?
Posted Tue 15 Nov 16 @ 1:43 pm
Read this thread. The answer is on page one.
Posted Tue 15 Nov 16 @ 1:46 pm
Use Accord it's like having 8 compatible filters ready to call from your pads.
Posted Tue 15 Nov 16 @ 2:43 pm
Thank you soooooo much for posting the answer!! I searched everywhere for this!!!!❤❤❤
Posted Wed 31 Jan 18 @ 5:58 pm
is there a way that a filter would show you all songs that have a value that is half the vale of the current bpm? for exampl..e if i have qa soing that is in 135 bpm
ans i wold like to find a song that has a vlue that is half this size so 136 /2 which is aproximately around 68.. it does not have to be exact.. just aproximate..plus 5 or - 5 margin..
Thank you!
Thank you!
Posted Sun 08 Sep 19 @ 4:42 am
