BOA NOITE AMIGOS,POR FAVOR MIM AJUDEM DU TENHO UMA CONTROLADORA DA GEMINI CONTROL 7 EU QUANDO COLOCO O CABO USB ELE RECONHECE PO 10 SEGUNDOS E DEPOIS APARECE Q O USB NÃO FOI ESTALADO CORRETAMENTE ,POR FAVOR MIM AJUDEM OBRIGADO.
Posted Wed 17 Dec 14 @ 7:48 pm
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the appropriate language forum (Where available) to post in your own language.
These other language forums can be found at the bottom of the main forum topic list.
Posted Thu 18 Dec 14 @ 11:45 am
Rookie at this need some help with setup virtual dj controls works from laptop only, CNTRL 7 is fully powered all lights are on but only the volume can be controlled from the system. What am I doing wrong?
Posted Sat 06 Jun 15 @ 6:41 pm
I'm also having the issue of no soundcard coming out. I've configured it the way they said to do it, still nothing. It won't light up or anything, the power light is the only thing on. It tells mee no sound card for Control Main. What can I do?
Posted Fri 19 Jun 15 @ 12:21 pm
I misplaced my serial number. I want to re-install my controller. Help
Posted Fri 11 Sep 15 @ 6:07 pm
gimini cntrl-7 cannot find my product code how can i find one
Posted Thu 15 Oct 15 @ 11:14 pm
Posted Fri 16 Oct 15 @ 8:16 pm
Help I registered the key, installed and updated my virtual dj but as soon as I plug Gemini cntrl 7 sub cable it keeps saying divice unknown and when it did not the virtual dj freezes till is closes. Sencond thing sound settings I have many options to choose from outputs eg. Rear, front, center and sound card I got five options to choose from same as the second column.
Posted Mon 14 Dec 15 @ 5:32 pm
CAN SOMEONE HELP PLEASE I'M RUNNING OUT OF TIME
Posted Tue 15 Dec 15 @ 9:44 am
hola buenas tardes a todos perdi el cd de mi controlador gemini cntrl-7 quisiera saber si alguien me puede ayudar con una copia del cd o los codigos de activacion es que no poseo tanto dinero para comprar la licencia
Posted Wed 17 Aug 16 @ 8:23 pm
