I have RELOOP Beatmix and Virtual DJ LE. I have updated all drivers and re-installed the program numerous times.
My problem is that there is no sound coming from the program. I have tried all the soundcard settings but no luck so far.
Could it be that the integrated soundcard is broken? I think that the program itself is broken in some way, because I get no sound with the primary soundcard either.
Please help, thanks.
Posted Wed 30 Jan 13 @ 9:29 am
Have you plugged a pair of powered speakers into the master outputs on the back of the Reloop Beatmix?
Controllers that have their own built-in DJ sound card such as the Beatmix are intended to be used with PA or powered monitor speakers. You will not hear any sound through your computer's own built-in speakers. However, if you are mixing for fun at home and wish be able to do this, then a solution can be found on our FAQ pages: http://www.virtualdj.com/wiki/VirtualDJ%20LE%20sound%20through%20computer%20speakers.html
Posted Wed 30 Jan 13 @ 9:40 am
