Hi,
Just got a Gemini Cntrl 7 and everything works fine except Im having sound issues:
1) Can you use an AUX cable for speaker output? It does work but it crackles sometimes - ive tried using different aux cables to make sure it isnt a wiring problem. Is there anyway of fixing this or will I have to buy a different cable? (Im using ordinary PC speakers by the way)
2) Headphones: These dont work at all when plugged into the MIDI controller, I just get an annoying high pitched sound coming out of them :/ (Yes I have checked that the volume on the headphones is turned up etc :P)
Could someone also tell me how to configure the Virtual DJ sound options please?
Thanks in advance :)
If you need anymore info just ask :)
Posted Mon 24 Dec 12 @ 9:15 am
