Hi
I do not speak English well, so I use the google translator, I hope we can understand
I have this problem
I purchased essential media and use it to play the files .mov
use win 7 in bootcamp on MacBookPro 15 i7 (2011) and Denon Dn-MC6000
I have assigned a button on the denon to activate the plugin essential media ( this is the script)
<map value="SEARCH-" action="device_side 'left' ? video_fx_select "SBDJ ScrollText" & video_fx : video_fx_select "Titler" & video_fx" />
<map value="SEARCH+" action="device_side 'left' ? video_fx_select "EssentialMedia" & video_fx : deck 1 fader_start & deck 2 fader_start" />
I can not perform the effect with the script:
when I pass effect made by the other,
the effect is activated but will not start
I also tried to map the keyboard, but I have not had good results
Can you help me?
best regards
Erik
I have this problem
Can you help me?
best regards
Erik
Posted Sun 16 Dec 12 @ 11:15 am
Hi Erik,
I will see if I can help you. I have your email and will respond that way.
Don
Don
Posted Mon 17 Dec 12 @ 1:04 pm
Hi Don,
thanks,
it helped me my great friend DJLunatico ;-)
Thanks and Merry Christmas to all friends of VDJ
thanks,
Posted Mon 17 Dec 12 @ 3:16 pm
