Forum: Old versions
Topic: Setting cues with Hercules DJ Console RMX
Hey everyone,
I am having a difficult time mapping and setting the cues on DJ Console RMX. I can do an initial cue using pause and cue button, but not more than that. I have buttons 1-6 mapped for loop in and out, loop durations, effect and sampler. How do I map using a shift (or scratch toggle) to get more use out of the buttons.
Posted Tue 11 Dec 12 @ 10:39 am
DJ PhatsoPRO InfinityHercules Support TeamMember since 2005
If you are using the LE version, then you are limited to 1 CUE point.
If yo are using the Pro Full verison, then you would be to assign anything you want to buttons from the MAPPER tab of the configuration menu, or by installing the Mapper Pack (registering your serial number is essentiel to access it from the Download section).
Posted Tue 11 Dec 12 @ 2:08 pm
