Forum: Old versions
Topic: audio diminishing on VDJ?
spin45PRO InfinityMember since 2012
First noticed it last night during several of the songs at a banquet I did, and now listening to songs with my headphones, I can hear different selections go in and out. It's not a big drop, but it's there, and I don't know why. I didn't change any settings, so I wanted to see if anyone has had this problem and how to correct it.
Posted Fri 07 Dec 12 @ 9:35 pm
Posted Fri 07 Dec 12 @ 9:44 pm
The VDJ version I'm using is 7.3 pro and I'm running Windows 7. Last week I had resized the skin and had ran into problems trying to get the skin back to its original state.
Posted Fri 07 Dec 12 @ 10:00 pm
go to User> Documents> Virtualdj> Skins and delete the zip file corresponding to the skin you were using.
This will force VDJ back to the default skin.
You can then redownload and install the skin of your choice once again and see if that makes a difference.
Keith
Posted Sat 08 Dec 12 @ 7:56 am
Downloaded the 3 skins that were in the file folder, and VDJ wouldn't open, so I had to restore the 4-deck one that I've been using. Found another song that goes in and out, although faintly, but it's still there, and with a couple of parties coming up this next weekend, I'm not sure what to do at this point to avoid sound compromising. I just noticed this problem this past week. What else can I do?
Posted Sun 09 Dec 12 @ 7:25 pm
Correction on my previous post, not downloaded, deleted I meant to say.
Can you describe the symptoms any better than "goes in and out"?
Posted Mon 10 Dec 12 @ 3:33 am
It's not likely to be related to skins unless you were maximising an old skin and that ups CPU use.
Please see my link in post 2 to try and configure your PC for latency issues.
Keith
Posted Mon 10 Dec 12 @ 6:34 am
