I just bought a new controller and I cant get my jogwheels to map to the virtual software. I can get some of my other key to work, the crossfader and pitch sliders etc., but I cant get the jogwheels. Can anyone help?
Posted Wed 05 Dec 12 @ 2:55 pm
What version are you using?
Posted Wed 05 Dec 12 @ 9:48 pm
Numark DJ2GO is natively supported by the latest version of VirtualDJ Pro Full and does not need to be mapped.
Please register your Pro serial number on your profile page http://www.virtualdj.com/users/edit.html and then download the latest version from the Download Center: http://www.virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html (Especially if you are working DJ and are making money as a result of using it.)
If your DJ2GO came with VirtualDJ LE included, then your LE serial number should entitle you to a discount (Unless it is second hand and has already been used.)
You can test it before purchasing for 10 minutes at a time by using the latest VirtualDJ Home FREE: http://www.virtualdj.com/download/free.html
Posted Thu 06 Dec 12 @ 7:58 am
