hi
as subject states, i am in the middle of a mix session and seem to lose sound after 10 min. i have re installed app with same results. its frustrating as i have to quit the file and restart app. any idea on how to fix? i am using a gemini mid cntrl2 with it.
this funny enough has started recently
would appreciate a fix
thanks
thanks
Posted Sat 17 Nov 12 @ 3:36 pm
What hardware are you using?
VirtualDJ LE is free limited software and will only work with the hardware that it was included with (Gemini CNTRL2 in your case.)
Full Pro features can be tried for 10 minutes at a time, after which it will revert back to the LE limitations, disabling any Pro features that you were using.
Please see http://www.virtualdj.com/wiki/How%20do%20I%20change%20the%20skin%20or%20use%20plugins%20in%20VirtualDJ%20LE%20or%20Console%20Edition.html
And http://www.virtualdj.com/products/comparison.html
Posted Sat 17 Nov 12 @ 4:49 pm
Hi. Yep it's the software that came with my controller. I'm using the Gemini cntrl2 on a I core 5 Lenovo laptop with 4 gig ram on windows 7.
Posted Sat 17 Nov 12 @ 5:27 pm
Oh I hang upgraded to full pro version nor clicked any trial buttons
Posted Sat 17 Nov 12 @ 5:29 pm
Meant haven't upgraded to pro , did not click anything. I have uninstalled and reinstalled it
Posted Sat 17 Nov 12 @ 5:30 pm
What other hardware do you have connected, if any?
What is your sound setup in CONFIG -> Sound Setup?
The 10 minute Pro trial will automatically activate if you try to use any Pro features such as another MIDI controller connected, full-screen video, Pro/advanced sound setup (E.g: Outputs: External Mixer), etc.
Because the Gemini CNTRL-2 doesn't have a built-in sound card, please see the following page for your options for sound configuration in VirtualDJ LE: http://www.virtualdj.com/wiki/Pre-listening%20with%20headphones.html
Posted Sun 18 Nov 12 @ 11:05 am
Only other hardware I have connected is via laptop speakers which are playing through my headphones jack. I also have an external USB sound card which I want to setup. Will have a look at the link though
Posted Sun 18 Nov 12 @ 10:26 pm
