Sou apantao sto ticket, alla blepo apantas se kapoia erotimata mou hdi edo.
To pithanotero einai pos allakses kati sto setup sou se sxesi me ton asio driver, px an to exes setarei me 2 cdj-400 kai prospathiseis na ksekiniseis to programma me to ena syndemeno mono kata pasa pithanotita tha krasarei opos les.
Dokimase na kaneis simple setup me tin onboard karta mono xoris mikti kai akoustika.
Meta syndese tis syskeues sou kai anoikse to programm, ksanakane tis audio rythmiseis.
Posted Fri 21 Dec 12 @ 11:29 am
kalhmera kalh xronia se oloys eytixhsmeno to 2013 . Mprabo paidia super doyleia synxarithria
Posted Fri 04 Jan 13 @ 12:53 am
entelos ksafnika simera sto asxeto, pao na anoikso to vdj sto desktop kai mou petaei auto to minima
to klino kai to ksananoigo kai pali to ido.
kano check/clean/fix kai....... xathikan oooles oi plirofories! bpm, cue, ktl
EUTYXOS kratao backup kai to arxeio database mazi me ta tragoudia, to epanefera apo to backup kai ola ok.
exei kaneis kamia idea giati to ekane auto?
Posted Sun 20 Jan 13 @ 8:17 am
kane kanena checkdisk sto disko..
Posted Sun 20 Jan 13 @ 4:51 pm
Ti douleia exoun ta tragoudia stoC:.???..Tha se malwsw Aledjo.....filika panta....
Posted Sun 20 Jan 13 @ 7:31 pm
tora pou to les... exo dei kai kati alla ypopta symptomata se arxeia.
Posted Mon 21 Jan 13 @ 7:43 am
sto desktop einai!
Posted Mon 21 Jan 13 @ 7:44 am
H alitheia einai oti sto support kana dyo fores mou exei tyxei corrupted Database sto C. Otan anoiga to Database xml arxeio, evriska kenes grammes kai dyo grammes telous (</database>). Kapoia fora episis eixa vrei ena <song> pou den ekleine ne </song>
To eukolo vevaia einai na anoikseis to arxeio kai na diorthwseis antistoixa lathi
To dyskolo einai na katalaveis apo pou proerxontai.
Gia to DevTeam to apotelesma (corrupted database) den mporei na voithisei apo mono tou gia na diorthwsoume to bug. Tha thelame na kserame poies kiniseis eginan gia na ftasei i database na "graftei" lathos, wste na to anaparagoume kai na to diorthwsoume
Aledjo, thymisou ti ekanes ! xexexe
EDIT. Min ksexnate oti stin database tou C grafontai kai ola ta Virtual/Filter/Favorite Folders pou dimiourgeite an toulaxiston 1 arxeio autwn yparxei ston C !
Posted Mon 21 Jan 13 @ 8:26 am
espaga to kefali mou gia na thymitho ti eixa kanei kai epireastike i database.
thymithika oti den eixa kati apolytos tipota! xexexe
to apodido se lathos ton windows i problima sklirou diskou, giati entopisa kai alla xalasmena arxeia.
px ena mp3 pou to exo xiliopaiksei, itan 0 bytes, eno sto backup pou perno itan ok.
episis kai kati alla arxeia allon programaton xalasane.
ara de nomizo na einai thema apo to vdj alla kati allo.
to koufo stin oli ypothesi einai allou.
eno ebgaze to error, anoige to vdj kai diabaze kanonika oles tis plirofories tis database.
afou loipon meta ekana check/clean/fix, tote svistikane sxedon ola.
apo 26mb pou itan i database, emeine 2mb.
mporei bebaia einai ta esvise epidi itan oi mises plirofories opos auto pou les me tis kenes grammes.
ti na po, i moni lysi einai taktiko backup!
(ta exo se 5 diaforetika simeia backup ta tragoudia kai ti database)
Posted Mon 21 Jan 13 @ 8:37 am
ΚΑΛΗΣΠΕΡΑ ΞΑΝΑ...ειχα αναφερθει πριν λιγο καιρο στο "λαπτοπ i3 2.40ghz 4gb με 64bit win7 black edition v3 sp1" παιζοντας με τον denon dnmc 6000...κρασαρει η ολη κατασταση "συνηθως" οταν παω να ακουμπησω την ροδελα του κοντρολερ (ενω παιζει η μουσικη κανονικα) μονο το master gain εχει ελεγχο ενω ειναι κολλημενο ολα τα αλλα ειναι παγωμενα...Αυτο συνηθως το "βγαζει" μετα 1-2 ωρες παιξιματος...ΕΚΠΛΗΞΗ ειναι οτι προσφατα επαιξα καπου 7 ωρες χωρις καμια ενοχληση του προβληματος. εχω αλλαξει τα καλωδια επικοινωνιας usb εχω αλλαξει την θεση κουμπωματος επισης - αλλα - παλι τα ιδια......χτες βραδυ 2 φορες μου κολλησε με περιπου 2 ωρες και 1 ωρα διαφορα.....ΠΑΝΤΑ ....οταν ακουμπαω την ΡΟΔΕΛΑ γινεται αυτο...οχι οταν φορτωνω το τραγουδι.....ΕΡΩΤΗΜΑ?....υπαρχει ΛΥΣΗ?.....(εχω βαλει την7,3 εκδοση)
"ΕΥΧΑΡΙΣΤΩ" για την οποια βοηθεια σας
Posted Thu 31 Jan 13 @ 8:37 am
Η λύση είναι μια κανονική έκδοση των Windows για αρχή. Και αν το πρόβλημα δεν λυθεί τότε (και μόνο τότε) μεγάλωμα του "jog trans init" απο το firmware της Denon
Posted Thu 31 Jan 13 @ 8:44 am
Ενταξει.....το προβλημα λυθηκε (ΘΕΛΩ ΝΑ ΠΙΣΤΕΥΩ) - ΕΚΑΝΑ ΞΑΝΑ ΕΓΚΑΤΑΣΤΑΣΗ την 7,3 + αλλαξα SKIN + Αφαιρεσα το ποντικι τελειως...Εχω παιξει πανω απο 5+ φορες με μεσο ορο τις 4 - 7 ΩΡΕΣ!....Απλα το μονον "κακο" ειναι οτι καμια φορα δεν μου κραταει τις πληροφοριες στα BPM..(δηλαδη αν βαλω το σωστο τεμπο).Τελος παντων...ΟΛΑ ΚΑΛΑ....THANKZzzz
Posted Fri 22 Feb 13 @ 7:25 am
Αν κάνεις edit το BPM και δεν σου το κρατάει τότε συνήθως αυτό υποδηλώνει πρόβλημα με τα δικαιώματα του δίσκου.
Αν ο δίσκος είναι εσωτερικός τότε μιλάμε σίγουρα για NTFS, αν είναι εξωτερικός τότε μάλλον για NTFS καθώς το FAT32 δεν έχει θέματα με τα δικαιώματα (αλλά έχει άλλα μειονεκτήματα)
Σε κάθε περίπτωση κάνε μια αναζήτηση τόσο εδώ στο forum (έχει γραφτεί παλιότερα σχετικό άρθρο) όσο και στο Google για να ελέγξεις τα δικαιώματα στους δίσκους σου...
Posted Fri 22 Feb 13 @ 7:31 am
απορια
εστω οτι εχουμε το security : always
το deck 1 παιζει καποιο τραγουδι και εχουμε το slider κατεβασμενο δηλαδη δεν ακουγεται στον αερα.
διαλεγουμε ενα τραγουδι απο το browser με το mouse και το πεταμε στο deck 1.
τοτε θα φορτωσει το τραγουδι στο deck 1
με το keyboard ή με καποιο controler, εστω οτι εχουμε mapperαρει καποιο κουμπι (και το enter) να κανει load.
αν το διαλεξουμε με τα κουμπια και το πατησουμε το κουμπι, τοτε ΔΕΝ το φορτωνει αλλα το πεταει στη playlist.
για να το φορτωσει θα πρεπει να κανουμε πρωτα stop το τραγουδι και μετα να πατησουμε το κουμπι.
γινεται να κανει το κουμπι οπως το mouse που φορτωνει αμεσως?
δηλαδη να φορτωνει στο deck που ειναι κατεβασμενο το slider.....
Posted Wed 27 Feb 13 @ 7:59 pm
Aldejo exw tin entypwsi pws toso to drag n drop me to pontiki , oso kai kapoio koumpi (shortcuts), kanoun akrivws to idio pragma.
Otan to deck den vgainei katholou ston aera, dld eite to volume fader einai sto 0, eite to crossfader stin alli meria, kai oi dyo tropoi exoun to idio apotelesma.
Posted Wed 27 Feb 13 @ 8:23 pm
κι 'ομως δεν...
δοκιμασε το. πατα enter οταν παιζουν και τα 2 deck εχοντας στο ενα κατεβασμενο το slider volume
Posted Wed 27 Feb 13 @ 8:33 pm
aaa ok, twra katalava...
Maparise to Enter san..
volume 0% ? stop & load : playlist_add
Posted Wed 27 Feb 13 @ 8:44 pm
:) κοντα εισαι αλλα δε δουλευει πληρως.
δηλαδη τη πρωτη φορα στο πρωτο deck δουλευει, αν συνεχιζεις να παιζεις και με το αλλο deck, τοτε δε φορτωνει
Posted Wed 27 Feb 13 @ 8:55 pm
το βρηκα!
deck 1 volume 0% ? deck 1 stop & load : nothing & deck 2 volume 0% ? deck 2 stop & load : nothing
Posted Wed 27 Feb 13 @ 9:15 pm
I need Serial Number provided1 Who can Help me????? :(
Posted Mon 04 Mar 13 @ 7:15 am
