unable to receive led response from Quneo .. any ideas/suggestions appreciated
I created the Generic Midi device xml :
<?xml version="1.0" encoding="UTF-8"?>
<device author="Atomix Productions" name="SIMPLE_MIDI"
sysexid="F07E00060200015F1E00000003010211F7" type="MIDI" decks="2" >
<button note="2-16" name="play" channel="2" deck="1"/>
<led note="2-16" name="led_play" default="play" channel="2" deck="1"/>
</device>
and here is the default Generic Midi mapping xml :
<mapper device="SIMPLE_MIDI" author="Atomix Productions"
description="Simple MIDI wrapper" version="720" date="04/11/2012"
priority="-10">
<map value="2-16" action="play" />
</mapper>
</device>
priority="-10">
</mapper>
Posted Fri 09 Nov 12 @ 6:59 pm
Ok so I did however try using both Simple Midi AND Quneo named files.
"Simple MIDI Wrapper only supports very basic MIDI mapping. Mapping LED's is not possible"
Whenever I save the definition file to /device I lose the simple midi wrapper and lose the ability to use the controller at all.
So I can use the Simple Midi to use the controller, just unable to configure/create .xml files properly to receive LED.... again any help appreciated.
Posted Tue 13 Nov 12 @ 11:13 pm
anybody ... (crickets)
Posted Mon 26 Nov 12 @ 6:37 pm
Try this:
<device name="QUNEO" description="QUNEO Midi" author="PhantomDj" type="MIDI" sysexid="F07E00060200015F1E00000003010211F7" decks="2" version="730">
<button note="0x64" channel="1" deck="1" name="PLAY"/>
<led note="0x64" channel="1" deck="1" name="LED_PLAY" default="PLAY"/>
<button note="0x24" channel="1" deck="2" name="PLAY"/>
<led note="0x24" channel="1" deck="2" name="LED_PLAY" default="PLAY"/>
</device>
Some notes:
1) You must convert named notes to their HEX value
2) Ch1 of your controller is CH0 for VDJ. Thus Ch2 of your controller is CH1 for VDJ
</device>
Some notes:
Posted Tue 27 Nov 12 @ 3:41 am
