Forum: Old versions
Topic: M-AUDIO Xponent & VDJ 7.0 MAPPING!!!! HELLP
Hey i had my xponent mapped before i reformatted my computer but now it wont work, and i cant download the mapper for this product from SBDJ anyone have a download link i can use or help me out????
Posted Fri 26 Oct 12 @ 9:23 pm
The Xponent is natively supported in the latest version of VirtualDJ v7.2 Pro.
Please register your Pro serial number on your profile page http://www.virtualdj.com/users/edit.html and then download the latest version from the Download Center: http://www.virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html (Especially if you are working DJ and are making money as a result of using it.)
NOTE: You need to be a registered licensed user to be able to download any custom mappers and other add-ons.
Posted Sat 27 Oct 12 @ 1:58 pm
Maybe you can help me out. The mapping seems good and it was ok before. Now, for some reason the Crossfader is inverted. 0% = right side, 100% = left side. Any reason for the inversion that you can think of? Or how can I fix that?
Posted Sat 27 Oct 12 @ 11:35 pm
It could be caused by activating crossfader_hamster
The skin might have an option for this, or you are using the 20-day Pro trial and are/were using a skin that has this option.
If your Pro trial is still active, map a keyboard shortcut to the action crossfader_hamster and then press it to toggle. Otherwise, download and install VirtualDJ Home FREE to do this http://www.virtualdj.com/download/free.html
NOTE: If you wish to be able to use features such as custom skins, mappings, etc. then you will need to upgrade to the full VirtualDJ Professional: http://www.virtualdj.com/buy/index.html - Your VirtualDJ LE for MixTrack Pro entitles you to a considerable discount of 50% ($149 instead of the normal full price of $299)
Posted Mon 29 Oct 12 @ 6:44 am
The Crossfader_hamster thing worked. Thanks. Still don't know how it got switched in the first place.
Posted Mon 29 Oct 12 @ 10:23 pm
eltondgPRO InfinityMember since 2013
GOT THE 7.3 VERSION BUT MY CUE POINTS ITS NOWHERE TO BE FOUND IN MY BUTTONS... CAN YOU HELP ME
Posted Tue 23 Apr 13 @ 10:25 pm
TonydjxHome userMember since 2014
Tengo un controlador M audio Xponent y suena pero al rato se va el sonido
Alguien me puede ayudar
Posted Thu 22 Sep 16 @ 4:38 pm
