Forum: Old versions
Topic: M-AUDIO Xponent & VDJ 7.0 MAPPING!!!! HELLP
Hey i had my xponent mapped before i reformatted my computer but now it wont work, and i cant download the mapper for this product from SBDJ anyone have a download link i can use or help me out????
Posted Fri 26 Oct 12 @ 9:23 pm
The Xponent is natively supported in the latest version of VirtualDJ v7.2 Pro.
Please register your Pro serial number on your profile page https://virtualdj.com/users/edit.html and then download the latest version from the Download Center: https://virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: https://virtualdj.com/buy/ (Especially if you are working DJ and are making money as a result of using it.)
NOTE: You need to be a registered licensed user to be able to download any custom mappers and other add-ons.
Maybe you can help me out. The mapping seems good and it was ok before. Now, for some reason the Crossfader is inverted. 0% = right side, 100% = left side. Any reason for the inversion that you can think of? Or how can I fix that?
It could be caused by activating crossfader_hamster
The skin might have an option for this, or you are using the 20-day Pro trial and are/were using a skin that has this option.
If your Pro trial is still active, map a keyboard shortcut to the action crossfader_hamster and then press it to toggle. Otherwise, download and install VirtualDJ Home FREE to do this https://virtualdj.com/download/free.html
NOTE: If you wish to be able to use features such as custom skins, mappings, etc. then you will need to upgrade to the full VirtualDJ Professional: https://virtualdj.com/buy/ - Your VirtualDJ LE for MixTrack Pro entitles you to a considerable discount of 50% ($149 instead of the normal full price of $299)
The Crossfader_hamster thing worked. Thanks. Still don't know how it got switched in the first place.
GOT THE 7.3 VERSION BUT MY CUE POINTS ITS NOWHERE TO BE FOUND IN MY BUTTONS... CAN YOU HELP ME
Tengo un controlador M audio Xponent y suena pero al rato se va el sonido
Alguien me puede ayudar
