I am using a Mid-2010 Mac Pro Desktop with Core Audio and cannot get my USB mic working. I am able to connect to my shoutcast stream and play music, but cannot get the mic working. I know it has something to do with the settings in the apple control panel, if they aren't correct you will just keep getting errors on the VDJ side, I know this cause I had it working once. I just purchased the 299 edition and I can't get the mic working. Any help with some settings would be greatly appreciated. I am using the USB Audio Codec for line in and out on my apple settings in the Mac control panel.
Posted Mon 22 Oct 12 @ 4:30 pm
You have to follow these informations ;-)
https://virtualdj.com/wiki/Recording%20your%20set%20or%20broadcasting%20when%20using%20an%20external%20DJ%20mixer.html
Posted Tue 23 Oct 12 @ 12:38 pm
Informations? Is that a new word? I'll give it a try.
Thank you.
Thank you.
Posted Tue 23 Oct 12 @ 1:43 pm
Didn't really help as that it does not tell or show what settings to use on the Mac end in the Sound Settings Control Panel, I know these settings must be exact for the software to function properly.
Posted Tue 23 Oct 12 @ 2:13 pm
Hey!
Whoever uses Listen2MyRadio for their shoutcast/web radio show, I need help setting up my mic thru the server. The broadcasting of audio files thru the new Virtual DJ 8 works, but I cannot seem to set up the mic right so I can hear myself speak during the broadcast. I did not have this problem with Virtual DJ 7.
Posted Thu 08 Jan 15 @ 7:32 pm
What equipment/hardware/controller are you using?
Posted Fri 09 Jan 15 @ 8:39 am
