Topic: PIONEER WeGo for Virtual DJ - MIX & WALKTHROUGH
Posted Tue 02 Oct 12 @ 3:28 pm
Awesome video! That filter sounds better then what we have now, is it a different one??
I just love videos that show VDJ like this!!
really liked seeing that controller in action, great tool!
nice nice ;)
Is it possible to control Virtual DJ Pro with the WeGo? Or only the limited edition?
Ok...DAYAMN that is a sweet ass "beginner" controller. At first I thought it was just pretty lights...But, they really packed a TON of features on that thing. I honestly like the feature set of that one better than the new Aero or SX!
I think Ima gettin' one of those! Not to mention, it just looks flat out fun to mix on with a touch of Tron style!
The WeGo is natively mapped in the latest version of VirtualDJ Pro Full (7.1)
it maybe labeled as a gateway drug but after having used one of these for a few days I gotta say this thing is pretty intense great controller for anyone.
I am strongly considering this to replace my vci-100. I think it would be a good replacement. What do you think Cyder?
I got a ddj wego and I allready had VDJ Pro on my pc and I installed the LE also. I want to make the Pro work the same as the LE with the controller because it doesn't respond to any button that I press to send command to the pc\VDJ Pro.
This is probably because you have an out-of-date version of VirtualDJ Pro that doesn't support the WeGo.
Please register your Pro serial number on your profile page http://www.virtualdj.com/users/edit.html and then download the latest v7.4 version from the Download Center: http://www.virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html (Especially if you are working DJ and are making money as a result of using it at your gigs.) Your VirtualDJ LE should entitle you to a discount off the cost of upgrading.
The version for the Pro is 7.04 so why doesn't works with the controller like LE does?
Setting or what does not work?
so this we go is better than the PIONEER DDJ-ERGO? since the WE GO is much cheaper
can pioneer ddj sb work with virtual dj le and how?
