Forum: VirtualDJ Plugins
Topic: Effect problem
How can I download effects? What license do I need?
Posted Tue 25 Sep 12 @ 3:18 pm
You will Need at least a Limmited Edition of VDJ or the broadcaster-Version or Pro-Basic.
regards
You can download effects with your VirtualDJ LE license, but this free limited software doesn't support using them outside of the time limited trial of the full VirtualDJ Pro - Please see http://www.virtualdj.com/wiki/How%20do%20I%20change%20the%20skin%20or%20use%20plugins%20in%20VirtualDJ%20LE%20or%20Console%20Edition.html
Your RMX entitles you to a considerable discount off the cost of upgrading to the full VirtualDJ Pro: http://www.virtualdj.com/buy/index.html
NOTE: VirtualDJ Console Edition for RMX is version v5 of the software, so newer add-ons designed for v6 or v7 won't work. You will get the latest v7.0.5b when you upgrade along with free update to v7.1 and v8 when they are released in the future.
Hey I have been using VDJ Pro for some time and got on here to get some video effects, it says I do not have the right permissions. How do I obtain permissions?
As above... you got to purchase the pro version.
OK where can I obtain my serial number? I have looked under info in the config and looked in the root directory but can't seems to find anything. Any help? I have purchased VDJ Pro probably over a year ago, does this make a difference?
Ok you are now registered in the forum, scroll up the page and put the cursor over "Download" and you will see effects, skins, etc, that is where you get them from.
