O KONTROLER MOU EINAI KENOURIOS MOLIS TON PEIRA GIA NA ANTIKATASTISO THN HERCULES REMIX.
EIXA STO MAC MOU TO VIRTUALDJ TO TELEFTEO SE PRO EKDOSH (OXI GNHSIA) ALLA DEN MOU DOULEVEI ME AYTHN.EVALE THN VIRTUALDJ LE KAI MONO ETSI PAIZEI.PAIDIA TH NA KANO GIA NA DOULEPSEI STHN PALIA EKDOSH OMOS ""XORIS NA XALASO LEFTA""
Posted Thu 12 Jul 12 @ 4:54 pm
Dystixws tha prepei na valeis to xeri stin tsepi, an theleis na exeis tin Pro Full na douleuei me tin konsola sou. To upgrade tha sou kostisei peripou $149 (konta sta 100 euro) an xrisimopoiiseis to serial tis RMX, gia upgrade (pou dinei megali ekptwsi).
To upgrade einai proairetiko vevaia. An to budget sou den sou epitrepei oute ena euro, tote i LE version einai mia lysi.
Thermi paraklisi, min grafeis me kefalaia.
Posted Thu 12 Jul 12 @ 5:19 pm
se efxaristw polu kai sorrry gia ta kefalaia
Posted Fri 13 Jul 12 @ 7:47 am
Agorasa virtualDJ pro alla tipota.Exo sovaro provlima.Otan eimai se MIDI se oti rithmiseis exo dokimasei ola mou paizoun se ena kanali kai den mporo na kano allages apo ta faders HELLLLPPPP!!!
Posted Fri 13 Jul 12 @ 9:18 am
Μην ανοίγεις καινούργιο θέμα... Ήδη σου απαντάμε σ' αυτό. Επίσης αν αγόρασες το VirtualDj PRO Full θα σε παρακαλούσα να ενημερώσεις το profil σου βάζοντας τον σειριακό σου αριθμό εδώ: http://www.virtualdj.com/users/edit.html
Posted Fri 13 Jul 12 @ 9:58 am
HELP exo virtualDJ pro ekdosi (pleon) me American Audio Encore 2000 se macbook Pro kai exo sovaro provlima.Den exo to deftero kanali mou paizoun kai ta dio kanalia tou virtualDJ sto aristero kanali.Auto simbainei mono otan paizo se MIDI
HELPPPPP!!!!
Ta parapanw einai copy-paste apo to allo thread pou anoikses alla kleidwthise...
Loipon, katarxin...sto Config tou VirtualDJ, prepei na exeis..
Inputs..None
Outputs..Headphones
Sound card 4out kai dipla American Audio Encore
Episis, prin anoikseis to VirtualDJ pigaine sto Applications-->Utilities-->Audio Midi Setup...epelekse tin karta ixou American Audio kai meta Configure i COnfigure speakers (den exw Mac, den thymamai). Ekei tha prepei na settareis tin karta san Quadrophonic
HELPPPPP!!!!
Inputs..None
Outputs..Headphones
Posted Fri 13 Jul 12 @ 11:36 am
Ta ekana ola auta alla den mou doulevei to crossfader.Otan to pirazo stin consola den kouniete sto programma.Oute ta alla pliktra den kouniounte otan ta allazo apo consola BASS-MID-TREBLE-GAIN....
Posted Sun 15 Jul 12 @ 8:43 am
An anoikseis to Config-->kartela Mappers, vlepeis tin konsola stin lista san American Audio Encore2000 i san Simple Midi, i katholou ?
Dokimase auto...
Pigaine sta Applications-->Utilities-->Audio Midi Setup, epelekse tin American Audio kai apo to panw menu epilogwn..kane ...View Midi Page.
Tha sou deiksei tis Midi suskeues.
H konsola prepei na exei to onoma... ENCORE 2000 WDM MIDI Driver
An onomazetai kapws alloiws, kane tin rename (diplo klik)
Meta anoikse to VirtualDJ kai des an ola douleuoun ok.
SIMANTIKO !!! An i konsola exei diaforetiko onoma, se parakalw, grafto edw, prin to allakseis. To xreiazomaste.
Den gnwrizw tin konsola, alla des kai to manual, mipws o mixer mporei na leitourgisei se 2 modes (analogue i midi). An nai, tha prepei na vreis ton tropo na ton gyriseis se Midi mode.
Dokimase auto...
Posted Sun 15 Jul 12 @ 3:23 pm
Twra molis eida oti yparxei driver gia Mac edw .. http://www.adjaudio.com/ProductDetails.aspx?ItemNumber=1467
Driver --> http://www.adjaudio.com/pdffiles/mac_midi_driver.zip
Egkatestise ton prin kaneis ta parapanw.
Posted Sun 15 Jul 12 @ 3:29 pm
Ekana akrivos oti mou grapsate.Tin ekana rename-tin eixe sto midi setup san ENCORE 2000.Evala ta drivers ta eixe se cd.Omos ekei pou paizei meta apo kapoia ora arxizei kai ""BRAXNIAZEI"" les kai exoun kaei ta woofer sta hxeia.Tin kleino kai tin xana anoigo meta apo ena me duo lepta o hxos entaxei alla meta apo ligo pali ta idia.Auto egine se ekdilosi kai eftixos pou eixa mazi mou tin Hercules Remix allios paei o gamos...tha epeza kateftian apo to MACBOOK PRO.Den xero ti allo na kano.Xriazome boithia
Posted Sun 22 Jul 12 @ 8:39 am
Yparxei periptwsi ta gains na itan psila ? To AutoGain sta Options kalo einai na to exeis sto AUto oxi sto Auto+Remember
Posted Sun 22 Jul 12 @ 4:15 pm
Mporei tha to kano auto kai tha xanagrapso.
Thanks
Thanks
Posted Mon 23 Jul 12 @ 6:28 am
Ta idia akrivos mou kanei pali.Tha trelatho telios den ginete auto.SOS SOS
Posted Mon 23 Jul 12 @ 6:52 am
Όταν μετά απο λίγη (κάποια) ώρα παιξίματος "βραχνιάζει" ο ήχος τότε αυτό 9 φορές στις 10 είναι λάθος ρύθμιση των drivers και ειδικότερα του latency της κάρτας ήχου.
ΔΕΝ ΞΕΡΩ τι γίνεται στα MAC. Πάντως εαν ήσουν σε περιβάλλον Windows θα σου έλεγα να ανεβάσεις το Latency κατά 1 με 2msec και να δεις αν διορθώνεται το πρόβλημα.
Posted Mon 23 Jul 12 @ 9:46 am
To evala sto max to Latency 2048(46ms).Tha doume pos paei.Pantos otan apo to Encore 2000 paizo me cds i me usb stick kateftian den exei provlima o hxos....
Posted Mon 23 Jul 12 @ 11:27 am
46ms είναι υπερβολή... :P
Θα σου συνιστούσα τιμές κοντά στα 10ms
Posted Mon 23 Jul 12 @ 11:38 am
Ki omos paidia to evala sto max to Latency 2048(46ms) kai paizei teleia.An to xamiloso to Latency sta 512 i 1024 vraxniazei pali.....
Posted Wed 25 Jul 12 @ 8:17 am
Poio Mac exeis ? me ti xaraktiristika ?
Des ligo edw merika pragmata pou mporeis na kaneis gia na exeis kalyterro performance http://www.virtualdj.com/wiki/Common%20Mac%20Performance%20Issues.html
Posted Wed 25 Jul 12 @ 10:14 am
Τότε αυτό χρειάζεται να το δείτε μαζί με κάποιον από το technical support που να γνωρίζει από MAC.
Δεν ξέρω πολλά πράγματα για MAC και δεν μπορώ να σε βοηθήσω. Πάντως βρήκαμε οτι για το "βράχνιασμα" φταίει το latency της κάρτας ήχου (ή τουλάχιστον κάτι που το επηρεάζει άσχημα)
Posted Wed 25 Jul 12 @ 10:16 am
tsifos pali vraxniasma....
Posted Wed 25 Jul 12 @ 11:16 am
