Topic: Muffling sound from my VDJ
Hi Guys,
I was wondering if anyone could help me? I keep getting these muffling sound from my speakers when I play on VDJ.
I just bought VDJ pro a few days ago, I have also got a VESTAX 300vci controller and a windows sony laptop (Windows 7).
I have tried playing it at my friends place and it works, but when I got home and tested it on mine system stiull got the muffling sound. Albeit he only has a set of computer speakers.
Any help pleases, I am pulling my hair out.
Thanks.
Posted Thu 28 Jun 12 @ 10:59 am
This could be caused by performance and/or configuration issues with your computer - Please see http://www.virtualdj.com/wiki/Performance%20Issues.html
Or it could be that you are using master tempo/keylock with the 'fast' algorithm - Depending on the amount of pitch adjustment, this will result in audio artifacts, usually most noticeably on some of the drum beats. Try choosing Quality Stretching in CONFIG -> Performances.
If I am reading you correctly, you are using the same computer and sound card just with two audio setups?
If so, I would guess that you may have a ground loop causing the distortion. If your computer's power cable has a ground pin, try without the ground (2 to 3 adapter or something like that) but be careful not to do anything dangerous while your equipment is ungrounded (spilling water on it, licking it, washing it in a bathtub, etc.)
Laptop power supplies are especially notorious for causing noise problems. Also make sure the power supply is nowhere near any audio cables as that can induce unwanted audio.
I hope this, or the previous post helps,
-Frd
IMPORTANT: *NEVER* remove or disable the ground connection. This can be extremely dangerous and could result in serious injury or even death in the event of a fault.
You can safely confirm whether a ground loop is causing the issue by disconnecting your laptop from the mains and running it from battery. If the problem stops, then you can resolve it by purchasing a ground loop isolator for your audio connections.
Please see: http://www.virtualdj.com/wiki/Ground%20Loop.html
