Forum: Old versions
Topic: Netsearch not working - Page: 2
NebulaPRO InfinityMember since 2004
Haha, problem solved! As its a backup I don't mind using an LE version. Now back to topic of netsearch
Posted Sun 18 Nov 12 @ 7:32 am
Having your full Pro installed on a second laptop as a backup on standby is permitted (Ready to go should you have any problems with your main laptop.) In fact, having two laptops (Main & backup) is strongly recommended and the reason we allow the software to be installed on up to two computers at any time for your own personal use.
You just can't be actively using it at the same time for normal DJ use as your main laptop.
Also, as above, you can also use your LE version at the same time if you wish because that is a completely separate license. However, LE versions prior to 7 will only work with the appropriate controller connected.
Posted Sun 18 Nov 12 @ 11:53 am
