having the same problem, when i play a track out loud its fine works great, but then i load another track into the second deck and start to listen to it through my headphones ready for mixing, im turning the knobs on the ddj-ergo and i notice its skipping very slightly and poping when i eventually put the crossfader over to play that track out loud and then the skipping continues, im running a macbook pro i7 processor 2.2GHz
4 GB 1333 MHz .. Sounds like its config issues to match my computer, can you tell me what the performance settings for mac is, thanks.
Posted Sat 25 Aug 12 @ 4:34 am
i have the same problem macbook pro core 2 duo vdj pro and ergo. When i load the 2 deck the sound starts having problems why????
Posted Fri 30 Nov 12 @ 2:21 pm
my guess is its the usb 3.0, the current audio drivers are not playing nice as they are optimized for usb 2.0
i gaurantee you use a earlier model mac w usb 2.0 and the problem will go away.
Posted Fri 30 Nov 12 @ 3:12 pm
