so can someone please explain to me why more then half the effects I down loaded end up having some virus problem and ends up screwing up when im mixing? Alot of the time before i click install on a effect i get a warning message saying this file can harm my computer do you wish to proceed? but i still go ahead and pay the price, alot of times i cant have a effect running on each deck or its starts skipping, or sometimes it skips with just one effect on. This is really disappointing so please does anyone else have this problem or is it something with my computer
Posted Sun 15 Apr 12 @ 11:39 pm
Anything downloaded directly from this site will not be infected in anyway shape or form.
Check this thread out for further information....
http://www.virtualdj.com/forums/105923/PC_Version_Technical_Support/Installation_error___Disable_NOD32_anti_virus.html?page=1
Posted Mon 16 Apr 12 @ 12:18 am
All Virtual DJ files are virus and trojan free.
The problems you are having are actually a performance issue with your computer - you need to check your sound setup, performances and things like DPC latency.
Regards,
Scott
Regards,
Scott
Posted Mon 16 Apr 12 @ 5:54 am
This is a false positive from your anti-virus software, which is very common for Norton Anti-virus.
Please see: http://www.virtualdj.com/wiki/Plugin%20virus%20false%20positive.html
Posted Mon 16 Apr 12 @ 5:57 am
